Question about Garden
Tractor won't start
After tractor set for a number of days I can't get it to start. It turns over but won't fire. Plugs are new . No gas is getting to the plugs they are dry
    Sergeant:
    Champion:
  • 257 Answers
Not a expert just trying to help,you did not say if it had fuel pump or not if so check it ,,and if not clean carb. hope this help
Posted on Oct 04, 2009
Farmall Super A Tractor won't crank
wateri in carb. Drain sediment bowl if you have one, install a new gas filter , inline, and then open the drain on the end of carb, small plug, and let all water out. Install a shutoff on gas line and when your done with the maching shut it off and let the tractor run out of gas. That way you will never have a condensation problem. My super A starts 1st time every time due to this precaution.
May 06, 2012 | Farmall IH Tractor A, B, Super A, AV Carb...
1939 c allis has gas and spark, but won't start
could have some stuck rings dump a little trany fluid down the plug holes and let it sit a coulple days
Mar 24, 2012 | Garden
75 John Deere 2030 gas tractor will not start. Changed plug wires, plugs, drained tank, new gas, new battery, new coil, new wires, getting spark turns over but does not fire.
first thing is to test and see if it is firing,if so clean out the carberater.
make shure all moving parts are clean inside and out,flotebowl,neddle valves,and jets should be
free of gunk and allow good flow of gas.
Jun 25, 2011 | Garden
Tractor won't stay running, back fires when I turn it off.
It seems as if the tractor was out of its correct timing, also try replacing the spark plugs.
Thanks
Jun 03, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
My 8n ford wont start with new carb, points, plugs, condensor, has a lot of spark at spark plugs and a lot of gas with both carbs I have tried, but no gas on plugs when I take them back out and smell for...
I have also changed my plugs, points, cleaned carb, but I can not get the tractor to fire at the cylinders. I have spark but will not crank. What do I need to do?
Jun 24, 2010 | Ford 8N Tractor
I was given a Case tractor. It needed a fuel
Is your fuel pump working? are you getting fuel to the carb?
1. check for spark
2. check for compression in all cylinders
3. check carb (if it's been a long time since it was last started, you will need to just take the carb apart and clean it or get a carb rebuild kit. rebuild kit is easiest route and once you do that, you are done fussing with it.
4. Diagnose the problem.
a. try starting fluid directly into the carb. If it fires up then quits you have a fuel delivery problem. Once you figure out that, you can trace the problem back from the motor to the tank.
5. If you don't have any spark, try new plugs, then try new wires, then start going over your electrical system
Oct 04, 2009 | NRS Garden
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
