Question about Kenmore KSM035 Stand Mixer
Hi, I have an CFX12 Mackie, yesterday after an event...a Led of the Trim(gain) that indicate zero level of the channel it turned on...and never tunrned off even I had not instruments plugged on it...I switched off the mixer and when I swithced on it the Led was still turned on...what is going on...? How can I fix this problem...? tahnks,
I take out the led
Posted on Oct 06, 2009
My KitchenAid 9708416 will not turn on at all. It worked fine the last time I used it.
You have not supplied the model number, that is the part number for the silver trim band that goes around the motor housing. Also as well as the model number a rough idea of how old your mixer is may be relevant.
Mar 28, 2017 | KitchenAid Food Mixers
Vision 708 mixer amp
Jimbo
I am not sure about the LED fault lights....but I have a few troubleshooting angles to provide a start:
Try checking the power supply at the output devices and compare with the good (Left) channel.
The distortion you are hearing may be due to
low voltage.
This is a stereo amp, so you have a good (Left) channel to compare with. Use a multimeter to compare resistances (no power applied) or voltages (power on) at the components working back from the outputs of each channel. When you find a difference you have located the faulty area.
If you can get an oscilloscope it can also be used to trace the path back from the output of each amp. Good Luck Be careful!
Jan 08, 2008 | Food Mixers
Trim ring does not stay attached after service...it keeps poping off. It looks like it is just a pressure fit
If your are talking about a KitchenAid mixer, tap all around on the bottom edge of the trim ring with a padded hammer. This ought to drive it into place.
Apr 28, 2016 | Food Mixers
How can I turn my clock on on my mackie d8b
There is a clock card inside you can not turn that unless you have an apogee clock card
Oct 25, 2014 | Mackie D8B Digital 8-Bus Mixer
How much oil does my H 600 Mixer hold ( Hobart in the Transmission
1 gallon of 90w Gear Oil -- can be purchased from AUTOZONE! Make sure when you have completely drained from the large drain screw from under the mixer toward the back of where the attachments go on but not part of the part that spins around known as the Beater shaft! Once you have drained out all of the oil -- from the top where the front screw attaches the head or cap of the mixer -- add the oil there and make sure you are watching the sight glass to see when it is at the HALF way mark in other words when the oil level (TIP: Use a bright led flashlight to shine directly at this sight glass to view level) reaches to the midway mark of the oval sight glass, THEN STOP! It is full! Carefully start mixer on 1st gear and then 2nd so on and so forth to make sure everything is getting relubricated correctly and slowly -- don't just go setting it on 3rd or 4th speeds as you want to baby the mixer when you just put in new gear oil
Hope that helps!
Jun 12, 2014 | Hobart H600 Stand Mixer
The cpu of my Mackie D8b no longer recognizes the keyboard or mouse and won't boot up.This problem just started after many years of trouble free use.
had the same problem once after a new install it still did not work
turned out to be the keyboard itself had a cable that wat broken solderd it and it worked again you can test this with a multimeter to see if the cables are still connected to the connector goodluck
Jan 14, 2014 | Mackie D8B Digital 8-Bus Mixer
Kitchenaid rrk5a not operating in lower speed settings
The RR of your model number stands for reconditioned, your actual model number is K5A, I believe that the side trim band says Hobart on the side, if not you may have a new trim band (Generic type) put on during the reconditioning to pretty it up. In any event in the back of the mixer is an end cover, at the top is a small Phillips head screw, remove it and lift the end cover up and slightly out, (because there are two small and fragile clips on the back that can be easily broken off, they help hold the end cover in place so up and out ) once the cover is removed you will see a black and copper plate with three chrome screws on it in an upside down triangle shape, the two top screws are for adjusting speeds from stir to 6, the lower one is for adjusting speeds from 6 to 10, Turn the screw on the top left to the left a quarter turn while the mixer is in the stir position. it should start turning. if not turn the screw on the right a quarter turn, the mixer should start, if not turn back the other way (both top screws a half turn) if it machine does not start then there is a strong possibility that it is the bottom screw, the bottom screw can and sometimes does get turned in or out due to the pressure caused by contact that it makes with the speed control switch bar attached to the side speed control switch, so let's try that one, turn it counterclockwise or clockwise (no more than one full turn) a quarter turn at a time, if it is the bottom center screw causing the problem then it should start within a full turn, try not to turn the screw in either direction more than one full turn as you can really screw up your speed settings. Don't panic I am probably making it sound more difficult than it really is, just remember that a little is a lot. I am a KA tech and every machine that I have worked on that has a low speed not working correctly it has turned out to be these 3 screws.
If your machine goes to high speed from the get go no matter where you put the speed switch, well that is another problem, but if your machine is not working on lower speeds when set to the lower speed and it does work at higher speeds when the switch is set to the higher speeds then it is the 3 adjusting screws on the speed control plate. hope this helps if not let us know
Jan 20, 2013 | KitchenAid Food Mixers
Mixer just hums, does not turn
has the armature worn down so the insulation is higher than the copper plate which the brushes run on,if so trim down to below plates
Jul 07, 2010 | Hobart A200 Stand Mixer
The silver band came off my KSM90 stand mixer. How do I reattach it.
The silver trim piece on you mixer can be reattached by taking the back off your unit. once this is done you will be able to see two screw holes on the left and right of your unit. simply wrap the band around the mixer correclty and use fine threaded phillips screws to attach the trim. hope this helps
Thanks
Oct 07, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kenmore KSM035 Stand Mixer Logo
46 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
john h
NOEL
NOEL
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
