Question about SpartaCom ModemShare Millennium (24-56200) for PC
Cant get modem share to work on my tablet... no com ports available
ModemShare is not compatible with Windows XP Service Pack 2 (SP2) or later, due to changes that Microsoft made to the DCOM security settings.
ModemShare is a now discontinued product, but the publisher provides an upgrade path to the replacment NetModem modem sharing solution here: http://pcmicro.com/modemshare/freeupgrade.html
Another option is to downgrade XP back to SP1, or use any version of Windows 2000 which is still compatible with ModemShare.
-Tim
Posted on Aug 19, 2008
Is it possible to use internet USB modem in sonny tablet model sgt111sa/s
Does the tablet have a USB port other than the microUSB port used for charging its battery ? Tablets, phones, iPods, iPads, laptops are mobile devices that connect to wireless (WiFi) networks, Your modem would have to be wired to a cable or phone jack, in which case, even if you can attach it to your tablet, your tablet becomes immobile.
Dec 04, 2014 | Computers & Internet
I hooked my tablet up to my tv via usb cord and cant figure out why i cant watch my netflix on the tv
On the TV you need to select the port for the USB. You should have a source select button on your remote for this. If not it is in our video menu. Second, you have to make sure there is not a setting on our tablet that needs to be turned on for sharing.
Jan 29, 2014 | Tablets & eReaders
How do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
IC VERIFY CREDIR CARD SOFTWARE WONT DIAL OUT AFTER SWAPING HD TO A NE PC. EXTERNAL MODEM WORKS FINE, SETTINGS ON ICVERIFY POINTS TO MODEM COM PORT. SOFTWARE WILL NOT DIAL OUT. aNY HELP?
Ok,
There's really only a few reasons this would fail beyond the COM settings. First, if the computer you're using has actual serial ports on the board and you're using a USB modem or if there are more than one serial ports it's possible you have either got the wrong COM assigned or that you have more than one trying to use COM 1. This will not cause conflicts with newer USB based devices but can when using actual UART chips on the motherboard or a mix of USB and UARTs.
Go into device manager and check for additional ports. Disable all COM ports except the actual modem and try again. If it still fails, check for DMA and IRQ conflicts. Do this by going into Start>All Programs>Accessories>System Tools>System Information.
Once open navigate to System Summary>Hardware Resources>Conflicts and Sharing.
Check for any conflicts with COM 1 and it's related DMA settings or anything sharing an IRQ with the modem. If you find any devices conflicting or sharing IRQ or DMA with the modem either disable the device or go into device manager, double click the offending device, click onto the resources page and find an alternate configuration that uses different IRQ/DMA that won't conflict. This will require a reboot for most devices.
Sorry my answer would be faster but I'm shaking almost a decade worth of dust and cobwebs out of my brain that have built up since the last time I even used a modem for ICVerify.
Hope this helps, lemme know how you make out,
chris
Dec 23, 2010 | Computers & Internet
Network printer is only available to 1 computer on network
In this case you are not using your printer as a network printer you are sharing your printer in your LAN and previously it was shared with a different ip and with new modem you are getting new IP. Do one thing try to ping all the computers and check if you get reply if not check your firewall settings. Try to reboot all the computers together and check.
Jul 24, 2010 | D-Link SWT DSL-504T ADSL MODEM with 4...
How to connect my dell dial up modum to lap top
Your dial up modem needs to be ab external modem.
You can not use an internal modem from another machine unless you create a network and share your connection.
If you have an external modem then connect the modem to the available port on your laptop and let plug and play take over. If you do not have a port on your laptop and you modem has a serial port you will need a usb to serial adapter which you can get at Radio Shack.
Jan 09, 2010 | Ultra Computers & Internet
I have 3 PCs -> 1st have 1 Ethernet port. (this PC have a laser printer, dual core processor, BSNL board band) -> 2nd have 2 Ethernet port. (1 is Motherboard inbuilt & other is connected as NIC...
http://www.geekgirls.com/windowsxp_home_network.htm
or
http://windowshelp.microsoft.com/Windows/en-US/help/76174f4a-7522-425a-9424-324dd299265e1033.mspx
or
http://video.google.com/videoplay?docid=-4885804885278005452#
Sep 20, 2009 | ASUS P5VD2-MX SE Motherboard
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Using wmc ir keyboard with tablet pc
Acer's IR ports works only for Remote control and certain compitable devices only. its not open port for all devices. It cant be used for other pheripherals as far as i know! If its bluetooth then it can work surely.
Nov 25, 2007 | Computers & Internet
SpartaCom ModemShare Millennium (24-56200) for PC Logo
Top SpartaCom Computers & Internet Experts
David Payne
David Payne
Are you a SpartaCom Computer and Internet Expert? Answer questions, earn points and help others
