Question about Maytag Neptune MDE6700A Electric Dryer
REPLACE POWER CORD WITH FOUR WIRE
Older model Neptune electric dryer need toREPLACE POWER CORD WITH FOUR WIRE DOES NOT HAVE COLORS TO INDICATE WHERE CORD SHOULD BE ATTACHED AND DO NOT FIND THE BAND THAT THE GROUND WIRE SHOULD GO ON
    President:
  • 1,304 Answers
Black far left
red far right
white middle
green goes to ground
Posted on Oct 03, 2009
What type of power cord do i need?
An electric dryer has an opening in the back, older units use a three prong cord, there will be three posts to attach cord, newer units have four prong cords, Bought separately. there will be four posts to attach, double grounded cord.
Jan 17, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Having to replace 3 wire power cord with four wire and can't find manual and unsure how to connect propperly.
Connect the colors with the colors on the dryer wires Black with black, White to white, and red to red. The green wire gets attached to the dryer cabinet on the screw on the outside of the access hole on left normally. on the exterior of the cover. Give me a rating if I helped you. Good luck!
Aug 22, 2010 | Maytag MDE308DAYW Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
The plugin on my dryer has the terminals going in a slant. the outlet in my house are straight. what should i do
You can purchase a dryer main power cord that fits the type outlet you have. Some cords are three wire and some are four wire. Here is some information on changing from a three wire to a four wire configuration or vice versa.These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the right/bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helped and best wishes.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Replacing a 3 prong cord with a 4 prong cord on a Maytag Neptune Model # mde4000ayw
Sep 27, 2009 | Dryers
Does the neptune dryer have a universal plug?
Dryers do not come with cords you have to buy them separately. Some houses have a three-wire system, which requires a three wire dryer cord. Others have a four-wire system, which requires a four-wire cord. This page will explain more on this as well as how to install a dryer cord. http://www.appliance-repair-it.com/dryer-cord.html
Sep 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
TRYING TO HOOK A 3PRONG CORD WHAT TO MAKE i"m doing it right
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
3 prong 4 prong
Aug 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
Maytag Neptune MDE6700A Electric Dryer Logo
106 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
