Question about GE Profile JTP18 Electric Single Oven
My GE oven is displaying "UnLock Door" when I try to preheat it. Yesterday I self-cleaned the oven. Everything when smoothly. Now it won't let me preheat.
  • GE Master
  • 19,396 Answers
Hi.
If this happened after a self cleaning cycle, then the high temperatures generated on self cleaning cycle may have damaged the door lock mechanism, or the wiring to door latch.
To start try disconnecting power, either tripping the circuit breaker, or disconnecting from main socket.
If that does not clear the error, then the door lock or the wiring harness must be replaced. The ERC must also be tested with attention to connectors and wiring going to the door latch.
In that case I suggest calling GE at the number listed on the owner manual.
You can also find parts and diagrams entering the full model number on this website.
Regards.
G.
Posted on Oct 03, 2009
Had cleaned GE oven yesterday using SELF CLEAN and today my oven will not work as it keeps flashing UNLOCK DOOR when the door is already open. Cant use the oven
There is a sensor/switch that sends a signal that the oven door is locked and that it is unlocked, it must be defective.
Jan 11, 2017 | GE Ovens
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Why is oven door locked and won't open?
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
Oven will not unlock after self cleaning
User manual says that the oven must cool off. I am sure this is not the case. Try starting the oven self clean function, and then clear/off to stop the function. Since the oven is cool, perhaps the oven will unlock.
Finally, you could try turning off the circuit breaker and then back on to see if it unlocks - unfortunately you will have to reprogram everything. All else fails, call a technician.
http://www.manualslib.com/download/58340/Ge-Jt912-Jt952.html
Mar 04, 2015 | GE Profile JT952 Electric Double Oven
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
49 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
