Question about Olympus FE-140 Digital Camera
The battery door will not clamp shut.
It seems the battery door will not clamp shut. A plastic piece is broken from the door latch. Any inexpensive way to have it fixed?
  • 3 Answers
Scotch tape.
Posted on Dec 12, 2009
  • 436 Answers
Only way is to replace the part with a genuine accessory.It won't be of a big cost.Please contact your nearest authorized service center.
Posted on Oct 03, 2009
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
Indesit d63 dishwasher, door locked shut. took top off+got to latch, the plastic catch wouldn`t pull out of the latch. undid it all, all seems unbroken but cannot seem to arrange the latch so that it will...
check with whoever you order the latch from, usually parts are individual for electrical parts and never assume that the screw or washer will come with new one, save every piece.
Mar 09, 2010 | Indesit 24 in. D63 Free-standing...
Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Film door latch is loose
Same advice I made to another post. At some point you got to make a decision. There is a lot of plastic pieces that can break. Canon doesn't support the T series from what I've read. You may consider getting another one. You also have to consider that the fix may not work. Then what do you do?
Sep 06, 2008 | Canon T70 35mm SLR Camera
Door Doesn't latch shut
Usually it's not thespring but instead the "latch head", which has a little loop on the backside to hold the spring. The loop breaks off.
The latch head is the long plastic piece with two protruding hooks which activate the hidden door switches.
The door will need to be taken apart (but not removed from the oven!) to get to the latch head. See the attached example photo.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Sharp R-1480 Microwave Oven
Closing the dryer door
you need a part number 5366021400 latch kit I think take your model and serial number to you local appliance dealer and they will probably have one on the shelf and its so easy to install just pull the old broken part out and replace with new one
Nov 15, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Faulty Latch Sensor
in the bottom corner of the latch there is a little piece of plastic on the hinge that pushes a switch that tells the camera the latch is shut if thats broken off thatll be the problem id shove a piece of a matcher in to see if it does the trick and if so its a new latch or leave the matcher :) 5
Sep 12, 2005 | Fuji FinePix S1 Pro Digital Camera
Olympus FE-140 Digital Camera Logo
214 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
