Question about TV Receivers & DVRs
Updating software when updating in progress error message is displayed and update does not complete
Re: updating software
I was wondering do you have the update software for a DSB 1500 Traxis. Thank you
Posted on Jan 13, 2008
0 characters
3 Points
PACE DVR. Please Help! Anybody
Try to google the message
May 13, 2013 | TV Receivers & DVRs
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
How do I update my humax box?
You have to getin to this site for a software update to your Humax Foxsat.
From ite main Menu, come to "Edit Channels" window and select the third option 'Software Update" and 'OK".
# When there is no new software to update, a popup will appear
# Software updates for products will be detected using the Automatic Update option
OTA - Over the Air Software Updates will be broadcast via satellite for the product when new updates are
available. Humax reserves the right for deciding when the software updates will be released.
Follow below to ensure that you receive the OTA Software Updates when they are released:
1* You are connected to a suitable satellite dish and are receiving the all of the freesat service.
2* The signal strength and quality are at a high level; if you are experiencing problems with the signal
then please do not continue with the download.
3* The product is in Standby mode each night allowing it to detect, download, and install the updates
when broadcast
* Please do not unplug the product from the mains during the software update procedure; this can
cause the product not to operate.
* Please do not remove the antenna cable from the dish from the product during the update as this can
* For information on the release of new software or the changes made please visit www.humaxdigital.
* The download can take between 5 - 10 minutes to complete.
* During the update process you will not be able to use the product.
* During the software update scheduled recordings will not take place.
* You cannot schedule programmes during software update
Sep 18, 2011 | Humax FOXAT HDR DTV Receiver
Failed software download error messages 02 and 10
My version is actually DTR 67500T but I did not realise that you had recorded a different model !! until too late.The shop replaced it with another box
Nov 10, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Problem retuning Sagem PVR6240T set top box
Hey Agoodwin,
Looks like you have missed the final software updates for the PVR72xx and 62xx series last year. The bad news is that Sagem are not likely to send another update for their old models. If you check your box settings and you have software version 0.4.5. or less, your box will probably not work again. Sorry, mate...
Oct 05, 2009 | TV Receivers & DVRs
Lost Channels retuning Sagem
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune.
See the address below for a chart of affected models, but the official advice is that you must contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
Sorry I can't provide you with a definite solution but I hope that I've at least reassured you that it's not something which you have or haven't done!
Please return the favour by rating my answer.
Oct 01, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Cyberhome DVR 1600, where can I get the firmware update
Hi there
The best bet now the company has gone bust is trawl through the forums to see in anyone has a firmware upgrade saved and available for download. Here is a good start.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Cyberhome DVD Recorder - DVR1600
Sagem pvr 6200T UK freeview box, display frozen.
I left the box and went for a walk!!!
About four hours after having freezed an error 09 message came up on the set top display and then everything returned to normal, after an on TV screen message that update had been successful.!?!
No difference in in any operation of the freeview box.
Note to self and other users
Updating the channel tuning does seem to work ok, though I have to vary between where channel 4 can be found - or learn welsh!
Jul 19, 2008 | TV Receivers & DVRs
Disc error with some DVDs
If the DVD recorder is an early model, it may be having trouble understanding some of the newer copy-protection schemes that are in use.
There's not too much you can do for this kind of problem, but you can try looking on the manufacturer's website to see if there's a firmware update for the DVD recorder. It would be something you would download and burn to a CD or DVD and then load into the recorder. That would update the DVD player's software so it can work with newer discs.
Dec 10, 2007 | TV Receivers & DVRs
TV Receivers & DVRs Logo
134 people viewed this question
Top TV Receivers & DVRs Experts
Jaime Hernandez
Are you a TV Receiver and DVR Expert? Answer questions, earn points and help others
