Ram problem? sometime my computer ram shows 1.75 gb of ram sometime 1.93 and sometime shows 2.00gb of ram .what is the problem in ram ?and no problem occurs of ram but why change the value of ram .in my computer two slots of ram and 1-1 gb of ram installed on different slots pease help me
  • 3,940 Answers
Most likely your system has UMA video (Unified Memory Architecture) which means that system RAM is used for Video. Many systems dynamically allocate RAM resources to the Video, thus you get the varying amounts of RAM accessible indicated. This is a normal function and system is working as designed.
Posted on Oct 03, 2009
Wont boot up
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Mar 03, 2013 | HP Pavilion a6347c Desktop /Athlon 64 X2...
Requirements for linux
If your computer shows 0.99GB Ram which means you have 1GB RAM so there will no issue if you install Linux in your PC.
Now Let me Explain Why it is Showing 0.99GB even though your RAM is 1GB, well .1 GB are used for your startup program like Desktop and some other application so there is no need to worry about it. when you install linux it'll take full amount of RAM, 0.1 GB don't make any difference.
Aug 11, 2012 | HP Computers & Internet
GA-8KNXP 4 X 1 GB Ram Bios shows 3.500 GB
This is because you are running 32 bit system. 32 bit system can only use up to 4GB RAM theoritically but some only 3.5 GB RAM.
Only 64 bit systems can use 4GB RAM and more.
Feb 02, 2010 | Gigabyte GA-8KNXP Motherboard
I upgraded my laptop's (hp compact cq40-336 tu) RAM from 1 GB to 3BG. I bought a 2GB RAM w/ Kinsengton model from our local store. TO find out the said RAM is not working properly. How can I fix this...
This model laptop requires DDR RAM. Sometimes different brand of RAM do not work together or not the memory upgrade was not compatible with the laptop.
To check the amount of installed memory, go into the BIOS configuration to view the RAM.
The other way is to open Control Panel and click on System, this will also show the total RAM installed.
Oct 17, 2009 | Compaq Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Mixing Memory
You can't install two RAMs with different MHz on a single motherboard. Sometimes it works but, usually one of the RAM gets busted. This is based on my experience though.
Sep 24, 2009 | Computers & Internet
2 rams nt working simultaneously
Are they exactly the same brand and model? Sometimes they dont like to mix and match. Say you have the Left and right ram slot. Does each single stick work alone in the left and the right slot? Sounds like you may have a dead ram slot.. :(
Jun 04, 2009 | Intel D102GGC2 Motherboard
Want to upgrade ram to 1gb
Kingston Value Ram will do, nothing over 533mhz
regards
Nov 24, 2008 | EliteGroup P4M800-M7 Motherboard
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
