Question about Olympus FE-340 Digital Camera
All my pictures turn out blurry
Please help it used to be very easy to take pictures just point and shoot now it seems like an impossible take to even take the simplest shot. I've tryed everything from iesp to spot to face and all the micro settings I've reset the camera. Please help
jackboy
  • 2985 Answers
SOURCE: olympus mji 700
It has to go back the Olympus for replacement or to seller if less than one year.
Posted on Sep 02, 2007
  • 919 Answers
SOURCE: memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Posted on Mar 23, 2009
SOURCE: Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Posted on Jun 20, 2009
rulds2008
  • 3866 Answers
SOURCE: Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Posted on Jul 13, 2009
  • 4090 Answers
SOURCE: When taking pictures outside bright white photos
I suspect that the film speed is set incorrectly. You need to change the value of the ISO from the menu button near the LCD. Scroll through the menu till you come to ISO ( on film cameras this was the old ASA) for low light conditions one pushed the ASA to a higher rating like ASA 400 which was more sensitive to light, thus better pics in a low light environment.
So you need the opposite and so 100 ASA ( ISO) should help you take better pics in bright sunlight.. you can go as low as 64 if your camera has a setting that low.
Apertures will be different for each ISO value selected so when you look through the lens you will see numbers like F16 in the display ir F8 in a lower light situation.
Rule of thumb
Larger the number smaller the aperture ( sharper the image and for bright light situations
Lower the number larger the aperture to let in more light
average light F8 and this is usually the one the flash selects
Use your manual to learn how to manipulate the ISO and your manual selection of apertures. Your photos wilol improve 100%
Please rate our help to keep the service online
Posted on Aug 24, 2009
When I take a picture with my 18-55 on a d3100 I hear and see through my visor that the image moves and a sound like a click, many seconds after taking the picture. It seems like it's still open and closes...
Giving the lens your using and depending on the shooting mode your in. I assume your shooting in a low light situation. The lens you have is not good for low light shooting because the F-stop is only 3.5 at widest, so minimal light gets in so the camera decides what speed to set it at to close the shutter. for example shooting in the school gym or church, the camera speed will be 1/20 second or even up to 1/2 second to get enough lighting into the sensor so the image is properly expose but for you to have a sharp image you will need to shoot on a tripod.
Without tripod and just handheld will create blurry images. I would suggest you bump up the ISO setting to minimum to 3200 or higher that way the camera speed will be higher and reduce handheld shakes that will create blurry images. But remember, increase ISO will increase in image grain.
That is why I suggest you invest into a 17-50mm F2.8 lens for low-lighting or 50mm f1.8 lens.
I hope this helps
Jet
Feb 23, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My samsung i8510's camera is always blurry, the
You cant just point and shoot!
Press the shutter and then wait until afew seconds until its finished.
May 15, 2010 | Samsung SGH-i8510 INNOV8 Cell Phone
Fuzzy images
Hey jjbeanwink,
This is a very nice lens, and is unlikely that your blurry images are caused by the lens. The most common cause of blurry pictures is that the shutter speed is set to low. A general rule would be your shutter speed should be at least 1/60th of a second while handholding the camera. The bigger the lens, and the higher the magnification of the subject you are using the faster the shutter speed you should use. If camera shake is the cause of your blurry pictures you could also try using a tripod. Another common cause of blurry images is subject movement, and one solution would also be setting a faster shutter speed. Another solution is using the flash to stop the action instead of the shutter speed. Of course manufacturers do occasionally make a bad product and that is why there are manufacturers’ warranties. If you just purchased this lens you could have an authorized service technician look at the lens and see if there is anything wrong with it. I these suggestions help!
Sincerely,
Allan
Go Ahead. Use Us.
May 12, 2008 | Canon 24-70mm f/2.8 Lens
Blurry pictures
yes you can most likely used adobe photoshop to fix this problem.
Apr 19, 2008 | Casio Exilim EX-S600 Digital Camera
Blurry pictures
Adobe photoshop might help.
Apr 06, 2008 | Casio Exilim EX-S600 Digital Camera
White Lines and blurry Pictures
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
I have a Casio EX 260, not the EX-S600
Try resetting camera. If that doesn't work more than likely there is a lens error. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Feb 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
BLURRY PICTURE
Shoot a faster shutter speed.  Push the button gently and hold the camera very steady.  Use a flash or higher ISO in low light.
Feb 03, 2008 | Canon PowerShot S2 IS Digital Camera
Olympus FE-340 Digital Camera Logo
83 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
