Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need the part number for the fuel line. It is a
I need the part number for the fuel line. It is a very, very small line. It is not more than two years old. PP 260LE.
  • markndeb82 Oct 04, 2009
    I was having trouble find stock fuel line this small. It is about 3.0mm OD. Think I might try a few more places before I order a factory replacement. Thank you so much for your reply, and the link.
  • dontbother10
    dontbother10 May 11, 2010
    I think you will find this beneficial also. Fuel Line Replacement SmallEng.comhttp://www.youtube.com/watch?v=JrXpU70Hm... HTH Lou
  • 403 Answers
Click on this link below to go to the Poulan parts store. I have it on the page for your item showing both your fuel lines. Just copy and paste into your browser.
http://www.partstore.com/Model/Electrolux/Poulan/260LE.aspx
I have found that you can get the same line at a automotive store. Just take the old line in and they can match it up to another line for you. This way you don't have to pay for shipping or wait on the part. Hope this helps, let me know if I can help you with anything else.
JimmyC
Posted on Oct 03, 2009
Testimonial: "Thank you so much for your help."
Fuel line routing on craftsman blower vac serial number 9528n06419
The small line goes to the fuel filter and the larger one is the vent to the fuel tank. The primer should have a large and small outlet and then you can put the small to small and the large to the large outlet. The fuel line from the tank goes to the carb. Hope this helps.
Apr 29, 2015 | Craftsman Garden
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Install fuel lines McCulloch 1838av chainsaw
to replace the fuel line you need to remove the cover over the carb and the fuel cap. (empty all fuel from tank) then use a small gauge wire to fish out the end with the filter in the tank. attach a small piece of small gauge wire to the fuel line. then remove the old line from the carb and pull the old line back from the tank. to anstall the new just reverse the operation.
Nov 06, 2014 | McCulloch Garden
Fuel line for ryobi
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers~~~hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ``
Feb 12, 2012 | Garden
Need to replace fuel lines on my Troy Bilt 4 cycle weed eater model number TB575CS. Where do the green and clear lines go into the tank?
Hi plomelino...
Maybe this diagram will help determine which fuel line goes to what connection
Please take time to rate me
Sep 13, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a woodsman 1800 and need the fuel line part number... looks like maybe 1/16 in line?
Cut a small piece of the line off, then measure the entire line. Take your sample and go to a car parts store and buy twice as much as you need. There are just a few sizes of fuel line and on lawn mowers there is no high pressure fuel line. No sense tossing a bunch of money away on fuel line with Poulan written on it.
Aug 21, 2010 | Poulan Garden
I have a weedeater xt 200 trimmer. The parts in
The tube in the tank is the fuel pickup line and goes directly to the carburetor. You will need to get NEW fuel lines. Fish or shake the old parts out of the fuel tank after draining. Inside the tank will be a small length of smaller diameter fuel line that connects to the small fuel filter and there will be a small nylon line connector that is plugged into the end of the larger diameter fuel line which is the fuel return line from the primer bulb back to the fuel tank. That line ends just inside the fuel tank and is held there by the small nylon line connector. The other line (smaller diameter) needs some length inside the tank so it can flop around as you move the machine enabling it to always pick up fuel. 6" or so is about right from the hole in the bottom (or top) of the tank to the fuel filter. Buy long enough lengths of fuel line that they can be inserted into the tank and pulled thru the fill cap area and then have the parts put back on them and then cut to the correct length from the fuel tank to the carburetor and/or primer bulb. Buy about 1 foot of each size line needed. Small engine repair shops have it and sell it..not expensive.
Jul 18, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I have a Polan Model 2375 Wild Thing Chain Saw. The fuel lines have deterioated and I need to know correct routing of fuel lines. The primer bulb has to line connectors, one small diameter and one large...
A Poulan IPL for your saw “2375LE Gas Saw Type?” (LE is code for WildThing; if your saw is beyond serial -2 look at a saw without the LE; it makes little difference to the fuel system) can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
  • Small hose (filter on bottom) long enough to reach all corners inside tank, to lower carburetor connection. Please leave the 2 carburetor connections long enough to reverse until the saw is running.
  • Upper carburetor connection, small hose to suction side of primer.
  • Pressure side of primer (large hose) to tank fitting.
The IPL is deceptive it appears the filtered hose connects to the primer; it does not.
A typical fuel system and suggestion or 2 follow:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Clogged fuel lines
fuel lines & filter can be looked at by a small engine shop & find replacements for them the fuel line should be 1/4 diamador
Jun 08, 2009 | Mantis 2-Cycle Tiller
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
141 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
