Question about Microwave Ovens
Micro wave stopped heating and makes a laboring sound. Turntable still goes around
    President:
  • 1,304 Answers
This could be one of two problems
either your rectifier fried
or your magnetron
the rectifier can be replacecd for pennies
but if its the mag well u may want to start looking
for a new unit
Posted on Oct 03, 2009
Prestige gs25 microwave won't heat
no the problem is more than your fuze! Micro waves have a high voltage output transformer inside that goes bad. You can fix it yourself but if your not good with electronics I would have someone else do the job!
Feb 07, 2012 | Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Micro wave not heating
It sounds like a failing magnetron. Sometimes they can be intermittent before they finally fail for good.
Chances are your oven has a 5-10 year warranty on the magnetron.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your detailed symptoms.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Dec 12, 2009 | Maytag Appliances Over-the-Range Microwave...
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
My micro wave will not heat products. All other systems are functional.
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 08, 2008 | GE Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
