Question about Cameras
Samsung 10.2MP Digital Camera won't work
I have a Samsung 10.2MP Digital Camera and it won't turn off and I can't take pictures. When I try to turn it off, it makes a beeping noise.
Adig
  • 104 Answers
SOURCE: Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Posted on Sep 11, 2005
jackboy
  • 2985 Answers
SOURCE: Lens not moving
The lens mechanism is shot. Depending on the age and possible cause of the condition- has it been dropped? I would think replacing the camera is a better option than trying to get it repaired -which I think is not a likely option
Posted on Jul 25, 2007
  • 4 Answers
SOURCE: Polaroid i533 digital camera
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Posted on Mar 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: how to fix my camera
If your close to a Best Buy, you can take it to the Geek Squad and have them take a look at it.
Posted on Sep 04, 2008
SOURCE: My camera is taking fuzzy pictures...
on the ting that spins go to program then hit the delete then go down to the sixth one and then to the 3rd one witch is coudy that how mine got fix
Posted on Nov 29, 2008
My Samsung PL120 won't take a picture -
The switch assembly is not making contact, needs to be repaired.
Jan 19, 2013 | Samsung PL120 Digital Camera
My camera works fine in all ways except whenever i turn the 'flash' on and try to take picture the green light just flashes repeatedly and it won't take a picture at all, but if i turn the...
Referring user guide:
Are you press ligthly? if press half and ligthly, it will not take the picture.
When you have using macro mode, you need to disable Flash mode.macro mode will show picture(flower) and avoid hand shake during this mode.
When you take in 10cm range in macro mode, it will take more longer time to autofoucus, you need to be freeze a while until it take the picture. The best it, try to take picture in without you inhale. it will avoid you from shage
Try using in different DIS mode when you using the flash.
In some mode, it will have twice flash. First flash it will check the condition and wait until second flash and dont move your camera.
Some condition, you will get the picture is white, it because from dust atmhospheric that we cant see. it reflective to ur flash.for the best picture, you need to try in different mode and different condition. that will make you as proffesional. this camera have many mode that you need to understand. training urself to be perfect. download manual and test your camera
May 12, 2011 | Samsung S860 Digital Camera
I have the usb cable for my samsung es30 but when i plug it in it doesn@t work, how can i copy my pictures
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 09, 2011 | Samsung ES30 Digital Camera
My Samsung SL420 Camera's USB cord is not properly working. It wasn't acting out like this before... but every time I try and download my pictures, I plug the cord in, and nothing happens. The camera...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 03, 2011 | Samsung SL420 Digital Camera
Hello. My daughter has had her samsung S73 for 3
The eye flashing is normal when the flash is trying to charge up , if the batteries are healthy the camera won`t take a picture until the flash is charged fully.Try turning the flash off and see if the camera fires, get some higher rated rechargeable batteries (2000mah) or above this may resolve your problem.
Aug 02, 2009 | Samsung Digimax S730 Digital Camera
Samsung L200 camera
there should be a sliding switch side of the memory card just slide it to unlock..
Jan 31, 2009 | Samsung L200 Digital Camera
Camera is frozen
My camera is frozen and it won"t turn off in less
I take out the batters.
Aug 18, 2008 | Samsung Digimax S630 Digital Camera
Lens is stuckpartly open power button does nothing-won,t turn off
mine has done this and I have grabbing the lens and pulling it out at the same time as I turn it on. It is a pain but it now works
Jun 24, 2008 | Samsung Digimax L730 Digital Camera
Camera says "memory full," but there's no pictures...
I had this problem, I don't know how it happened. I have the samsung digimax s500, this is what I did. 1 press menu 2 go to 'setup' 3 scroll down to 'format' 4 click right and scroll down to 'yes' that fixed mine, good luck
Jan 29, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
