Question about Honeywell Programmable Thermostat Heater
Trying to replace honeywell T8001C thermostat with new honeywell RTH7600. The old had a brown not used & a blue. On the new unit not sure where they go. Hooked it up with red,yellow,white,green & cool/heat does not kick on.
    President:
  • 1,015 Answers
Red is usually hot side of transformer,yellow is for the a/c compressor,white is for heater,green is for the blower fan,now the blue could be energize for heat or the common side for the transformer,brown can also be the common side of the transformer. It sounds like you need the blue wire connected to the common side for the thermostat....but be careful. Some units use this as a energize wire and are not a common. I would find out what furnace model you have then look online and double check what this wire is or you could damage the new thermostat and/or the 24 volt system on your fau. And also always have the power to the unit disconnected so you do not ground a circuit.
Posted on Oct 03, 2009
Replacing Thermostat I'm replacing our current battery-operated Honeywell thermostat with a wifi Honeywell thermostat. Our current one does not have a c wire hooked up to it but it does have two unused...
The c in the furnace that is white is going to your condenser, it must stay. ADD the blue that goes to the tstat OR brown, which ever and then use that color on your new tstat and you will be fine. Always turn power off when changing stat
Sep 26, 2017 | Honeywell Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Where do I put the wires on my honeywell thermostat RTH7600. they are black green red and white
This is the official installation guide for your thermostat. Go here:
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Jul 06, 2012 | Honeywell Programmable Thermostat Heater
Old wiring looks like this yellow =y1 green =G white=w2 orange =O blue=C red=R installing a Honeywell RTH7600 where does the orange wire go we have a heatpump.L
If you have a heat pump, the thermostat that will operate it most generally will have an "O' terminal for the orange wire, this is the circuit that energizes the reversing valve on the heat pump, be sure that the stat says heat pump on the box. hope this helps
Nov 02, 2009 | Honeywell Electronic Programmable...
How to hook up Honeywell rth 7600. have an extra wire
From what I'm seeing the 7600 is not compatible with a heat pump. Where are you landing the orange wire?
May 12, 2017 | Honeywell Heating & Cooling
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
I have a carrier air/heating unit with pump. It has 8 wires. Brown,blue, white, yellow, green, black, orange,and red. I'm trying to install honeywell thermostat. The wires from my unit are suppose to go...
Turn the power off to the air handler. Open the control cover. Write down what color wires go together at the wiring terminal. All 8 wires are probably not used.
Post the findings here.
In most cases,
E= brown-emergency heat
AUX=white-auxillary heat to supplement HP
Y= yellow-to compressor for heat or cool(hp)
G=green-indoor fan
O-orange-reversing valve on HP when energized in COOL
L=t-stat light(probably not used)
R=red-24v incoming power
B=black-reversing valve on HP when energized in HEAT
C=blue-common wire for 24v
Only one of the "O" or "B" will be used. Not both.
Apr 27, 2009 | Carrier Heating & Cooling
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
494 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
