Question about Freezers
My Frigidaire side by side is not making ice. (Model GLRS267ZAW1)It goes through the cycle but no water is getting into the icemaker. I can pour water in to the icemaker and it makes the ice and dumps it. What else besides the valve on the back could be causing this?
  • 4,070 Answers
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Posted on Oct 03, 2009
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm down) if it makes ice then the icemaker is ok. if it dont then hold up.
if it makes ice then either the water pressure is too low (or no water) or the water valve is bad. (to check water valve you need a volt meter).
ok back to hold up part... the icemaker actuallys controls the water valve so you can have no water but that doesnt mean the icemaker is bad. so here are the three possiblities to your problem:
ice maker
water vavle
not enough/no water
before you buy anything let me know and we can go over this again
hope this was helpful (or confusing sorry)
Apr 02, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Have viking side by side referagator , freezer model # ddrb304. I installed copper line to ice maker yesterday It is not making ice. Checked that water supply is on. Appreciate any suggestions Lou
make sure you have strong water pressure to the frig.
Do the ice maker have a shutoff arm? or a shutoff switch? either way make sure it is on. by now there should be water in the icemaker tray. if not then manually pour 1/2 cup of water into the icemaker. if it does make ice then replace the water fill valve.
if there is ice still in the ice maker tray you still have to check the water fill valve before we can say the icemaker doesn't work.
need a meter to check the continunity of the water vavle. if the valve is open repalce valve, if there is continunity the the valve is good.
hope this is helpful. if you cant do this ask a friend who is an electrician to help you
Mar 27, 2010 | Freezers
Frigidaire icemaker wont fill with water. Side by side model. The icemaker motor is working but water is not filling in to make the ice.
Take a blow dryer and try to thaw the tube out. It may have froze on you. Please leave good thumbs up for my guess Thanks The Raz Shack
Feb 20, 2010 | Freezers
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Sears side by side fridge model# 10652542101. ice won't work but water works fine. have heard that icemaker screen may be the issue, but would like a manual so i can clean or repair it. sears has no...
There is no "screen". Most of these units have dual water valve on rear of unit (two valves on one mounting bracket) located on lower right side of unit. Follow inlet line to where it terminates, you will see water valve. First thing to determine, is the ice maker making ice and not dropping it thru door, or no ice dropping into bucket. Stick finger into I/M and see if you feel ice or if it is empty. If empty (no ice) chance are that I/M is problem, not water valve. Check I/M by pouring water from small glass into I/M,let sit for 2-3 hours and see if it drops ice into bucket, if it does, possible bad water valve, if it doesn't, bad I/M. Those are standard I/M & water valves, available at most applianc parts stores including sears.
Sep 23, 2009 | Freezers
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
Ice maker is not making ice. I can see no other problem and as far as I know the freezer was not left open as there is no frost buildup inside the unit. Everything is frozen, only problem is NO ICE!!
Pour about 1/2 cup of water into icemaker and see if it dumps the cubes after a few hours . If it does , and icemaker does not refill , then water valve is the problem . If the icemaker never dumps the water poured in , then icemaker is bad . ALSO , check to make sure the coils under refrig are clean of dust , lint , etc . Icemaker has to be 5 degrees to operate .
Jul 22, 2009 | Freezers
GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
Jul 04, 2009 | Freezers
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
145 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
