Question about Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
Want to set up my sky remote to use with viao desktop c
  • 45 Answers
Your sky remote will only operate your SKY box & tv. You cant use it to operate a PC. You will need a seperate remote like the Windows Media Center Remote if you are using Windows.
Posted on Dec 22, 2009
New sony tv doesn't recognize cable channels
Normally the TV has to be connected to a set top box supplied by the cable company. The TV set usually needs to be tuned to channel three (or four) and kept at this setting. If an HTMI connection cable is used look for a button labled "input" on the TV remote and using the remote change the input selection to tch the HTMI input station you plugged it into .
Oct 06, 2014 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
What is sky remote code for LG 42LB5500
It depends on the Rev. number of your remote. Older Sky remotes are programmes for different models compare to new ones.
A surerfire way to set this up is to use the Sky "Program my Remote" feature from the Sky box itself (it's in the Help menus), or direct from the Sky web page: http://sky.uebv.com/ Each way will ask you to chec k the revision (rev) number from the sticker inside the battery compartment.
Sky com Find your remote control code
Sep 07, 2014 | LG Televison & Video
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
How do I stop my viao locking me out if I dont use
If you are using XP, it's control panel/display/screensaver...set the wait time to whatever you choose.
Then click the 'power' button, and set your 'turn off monitor', 'turn off hard disks', 'system standby', and 'system hibernate' times.
If this helps plz do the testimonial thing.
Oct 23, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Sony viao pcv 6603
check whether your RAM is OK. If the ram is gone then this kind of error could happen
Jul 13, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Computers & Internet Logo
67 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
