Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Usb device not recognised
I've been tryin to connect a IDE hard disk to my PC (Win XP) through a USB port. But i'm unable to get this retrieved. I checked in device manage / Disk management, but this storage device doesn't show there as well.
could you pls.help in getting me a sufficient drive?
Thanks,
Tony
  • johntony99 Dec 22, 2007
    Hey, thanks for the message. U see, I'm not a professional computer guy ok :) Im trying to connect a IDE hard drive where I have a lot of mp3 and movies stored. When connected, the device status message box this says 'No drivers are installed in this device' the following is the driver information;
    Driver provider: Microsoft
    Driver date: 07/01/2001
    Driver version: 5.1.2600.0
    Digital signer: Microsoft windows publisher
    When I click the driver details button, it says 'No driver files are required OR have been loaded for this device'
    Dunno from where I can get this driver? Could you please help?
    Cheers,
    Tony
  • Anonymous Dec 19, 2008
    same problem here
  • 1,006 Answers
First try this OPTION:
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
IF STILL NOT WORKING JUST BUY NEW EXTERNAL ( JUST EXTERNAL NOT HDD )
And rate me as fixya if u got help!
Posted on Dec 22, 2007
  • arben pllana
    arben pllana Dec 22, 2007
    If you load WIN XP SP2 you don't need a driver for HDD.
    • Easy to set up, easy to use -- Installation is a snap because you don't really "install" this drive, you just plug it in and it's ready to use. There is no CD to install; the included software loads from the drive the first time you plug it in.
    • Dual interface — For all-out, high-speed performance, FireWire 400 is the interface of choice. For convenience and compatibility among multiple computers, USB 2.0 is the way to go. How do you choose? With this drive, you don’t have to choose — you get both interfaces on the same drive.
    • WD Backup™ software — We've provided software that makes backing up your data as easy as possible. With a few simples steps you can back up all your data files or just save your picture and music files. You can also set scheduled backups, so you don't have to think about it again.
    • Capacity gauge — See at a glance how much space is available on your drive.
    • Intelligent drive management features — The My Book drive turns itself on and off with your computer and Safe Shutdown™ prevents the drive from being powered down until all your data has been written.
    • Smart design — The elegant case, iconic of a book, takes up less space on your desk, stacks horizontally, and allows two or more drives to nestle neatly together like volumes on a shelf.
    • High quality hard drive — Inside the case is an exceptionally fast, ultra-quiet, cool-running hard drive from Western Digital.
    • Free Google™ software — Search your drive, manage your photos, and simplify Web searches with included Google software. Note: Google software is compatible with Windows 2000 and XP only.
    Ideal For
    • High-speed backup of important documents and images
    • Extra storage for your computer
    • Automatic backups of your existing hard drive
    • Archiving the music stored on your MP3 player
    • Adding plenty of space for digital video capture and editing
    • Saving and organizing your digital photo collection
    System Requirements
    • Available USB Port
    • Windows® 2000/XP/Vista™ or,
    • Mac® OS X 10.3 or later
    Package Includes
    • USB 2.0/FireWire external hard drive
    • USB cable
    • FireWire cable
    • AC adapter with power cord
    • Quick Install Guide
    Important interface information
    This drive requires a USB or FireWire® connection
    [WD Interface Guide]
the usb connection is only for expand capasity
Posted on Dec 23, 2007
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
I have 500GB transcend Portabale hard drive but not working,need installation driver or some thing other ?
External hard drives connected to the USB port do not require any additional drivers for WIN XP, Vista or Win 7. If it is not being recognised at all then the USB converter inside the box is faulty. If the PC recognises the USB converter but not the hard drive then the hard drive may be faulty.
Feb 20, 2011 | Computers & Internet
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Sony Vaio USB ports not recognised by XP
It is common problem on most of the PC USB ports does not recognise external hardware.It is mainly due to lack power supplied by the USB Ports..You can try with Old Pentium4 maschines.IT Reads well..
Another thing dont use extension ports to plug external HDD..always use backside on board ports.\
IF it helps rate me
Jun 25, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
Can't recognise my Hard Drive with a USB to IDE cable.
Aside from what you're trying you can also use ubcdwin4 to create a boot cd which may give you access to the data on your friend's hard drive (with network support for copying the data to another PC), it might be worth a look.
As far as your WD is concerned, if you have the ability to remove the drive from it's external case and plug it into the system via the IDE plug you may have better luck. You may also want to try changing the bios in order to boot from USB device and plug the WD into one of the USB ports.
Feb 22, 2009 | Gateway Computers & Internet
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Usb not recognized
if you use it on win 95 or win 98 or vista you need specfic drivers for you usb disk
if you get this on win xp please change the usp ports and use another port to insert the disk one of the ports has to recognise.
if the problem persists the usb port controllor on motherboards needs to be checked for faults or uninstalled drivers ,
if nothing works try a pci to usb internal card and dont forget to loaad drivers . this card has 3 to 6 ports for usb
Jun 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
459 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
