Question about Vizio L30WGU 30 in. HD-Ready LCD Television
I cannot turn my DVD player on
I cannot turn my panasonic DVD player on - recently hooked up to a new Vizio flat panel television
  • Vizio Master
  • 19,396 Answers
Try first using the buttons on the unit to turn on the DVD, so to exclude the possibility of a faulty remote.
If the DVD player does not start at all, and there is not even the led light coming on, then the DVD power supply unit is faulty, in that case call Panasonic.
If instead the DVD stays in standby, with led light on, but does not start, then the DVD player is in protect mode.
Protect mode is a diagnostic mode that kicks in when a wrong voltage is detected. It can be caused by an internal fault or an external event like a power surge. The protection circuit will start, preventing the unit from turning on and keeping it in stand by.
If the problem is external, like a power surge, or a short on one of the connected cables, for example, the problem is fixed simply leaving the power cord disconnected for about thirty minutes.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same protect mode because of the video cable.
If the DVD is still going in standby after disconnecting, and there is no cable connected, then the unit has an internal fault.
In that case, if under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Try first disconnecting and unplugging video cables.
Posted on Oct 03, 2009
When I changed my vizio channel selector so my dvd would work now I am trying to get it back of channel 3 without is saying antenna under the 3
try doing a channel scan without the dvd player attached.My dvd player is hooked up thru a HDMI cable.
Oct 15, 2014 | Vizio SV470M LCD TV
Vizio E370lv television saysno signal but plays dvds
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | Vizio GV42L 42 in. LCD Television
My tv stopped working with my DVD player
Call Vizio for a warrenty repair.Ur DVD Combo,the laser eye is dirty,must take the tv aparts and clean it.But it under warrenty,take ur warrenty from Vizio let them take it aparts,can clean it for u.
Apr 06, 2010 | Vizio VA19LHDTV10T 19 in. LCD TV
What cables do you need to connect a dvd player to a vizio hdtv
If your dvd player has a hdmi hook up "easy" just use 1 hdmi cable from the dvd player to the tv. If not use the 5 cord for better picture quality.
Nov 08, 2009 | Vizio L32 32 in. LCD HDTV
DVD hockup to 37"VIZIO TV
There is no reason that any video player with RCA video/connections cannot be used with your new TV. However, you will not experience any increase in definition, even if your TV is High Definition.
If you used a Component connection from your DVD player (three cables for Video), all that is required is that your TV have Component cable inputs.
Oct 10, 2009 | Vizio L37 Television
Vizio vw42lf hdmi problem
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Aug 13, 2008 | Televison & Video
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
42 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
