Question about Denon AVR688
Denon avr-688 stuck in protect mode
My denon avr-688 amp has gone into protect mode after a few months of use, and now after having been shut off for weeks/unplugged, its still stuck in protect mode
techman
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • 4234 Answers
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Posted on Aug 19, 2008
  • 163 Answers
SOURCE: I have a Denon AVR-688
Try to reset the unit: hold "speaker A" and "Speaker B" buttons and power on the unit. Display will be flashing, release the buttons after 3 seconds. If the problem still there, most likely you have bad digital signal processing (DSP) board - send the unit to repair facility.
Posted on May 19, 2009
Switches off after five seconds.AVR-590
There are a few things that could be causing this to happen. The first thing you should do is check all the speaker wires connected to see if they might be touching each other somewhere. What you are describing sounds like there might be a short. Also, is the receiver well ventilated? What is happening is that it is protecting itself but shutting off.The 590 is going in to Protection Mode due to some fault it perceives. The quick flashing red power light (as opposed to a slower flashing light) would indicate either speaker wires touching another terminal, driving 4 ohm speakers to loud, or amp failure.
Jan 18, 2016 | Denon Audio Players & Recorders
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
My avr-688 will shut off out of the blue and will flash a red blinking light
It sounds like it might be the overheat protection problem described in this thread. http://www.fixya.com/ThreadView.aspx?prdid=622921&thid=3736114 Your amp has a thermal protection circuit which shuts down the receiver to prevent damage from overheating. Most often this is due to using speakers with an incorrect ohm rating, such as using 4 ohm speakers in a system designed for 6 ohm . It can also occur from using 6 ohm speakers in both the A and B front channels at the same time. If you have speakers attached to both the A and B try removing one set and check if this makes the system stable.
Nov 08, 2009 | Denon AVR688
Denon avr-688
I have the same problem with my AVR-688, were you able to find a help?
Sep 18, 2009 | Denon AVR688
Avr 688 shuts down immediately after powering on
Internal problem with power supply or one of the channels. Bring it to a repair facility.
Aug 09, 2009 | Denon AVR-685 6.1 Channels Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
Jan 03, 2009 | Denon AVR688
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Denon AVR688 Logo
129 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
