Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
I have an old electric mcculloch sprocket tip chainsaw but no manual and I'm not sure how to use it. Not sure if I just use chainsaw oil and also there is a black knob that turns and I'm not sure what it's for. Can I get a copy of the manual e-mailed to me. Thanks for your help. Lorrie
plkruger
  • 32 Answers
SOURCE: Mcculloch chainsaw 2014 Eager ****** Model 00032-14
call 1-800-521-8559 select parts, ask them to email a owners manual to you, it's free, it's EZ
Posted on Feb 19, 2009
  • 5 Answers
SOURCE: Where can i purchase sprocket for mastercraft
the new company is Troy-bilt but i found the part in a Mcculloch dealer
part # MC-6228-120104P
Posted on Jun 29, 2009
dontbother10
  • 2220 Answers
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 28, 2009
dontbother10
  • 2220 Answers
SOURCE: Mcculloch chainsaw. Model 2116av. Primer bulb is
Hello Jeff;
Your saw is listed here:
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. The primer is displayed but not listed, and there is no part number. Before you get to deep please contact OrderTree.
http://www.ordertree.com/cms/parts-lookup-help/73.html
Use the IPL as a guide for disassembly/reassembly.
This is typical routing and a couple of hints.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
OMs for McCulloch are tough. harder than replacing the fuel line. Have your saw within easy reach they will want the serial number and a few other things.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Good luck with your project. HTH
Lou
Posted on Feb 20, 2010
dontbother10
  • 2220 Answers
SOURCE: I am trying to obtain a copy of McCulloch 338 Chainsaw Manual
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Include your e-mail address in your request.
Posted on Apr 09, 2010
Stripped sprocket on EM450S-16
ebay has them but you'll have to pay about 30 bucks for one. I would recommend buying a gas powered saw.
Feb 24, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch Chainsaw Gear Drive Sprocket stripped
Ken's Repair Have 9 totes of parts for McCulloch saw Weed eater Modal # and Serial # Please
I have a McCulloch Mac 310. The chain seizes up after a few minutes use. When it cools down the chain will move. I replaced the sprocket. I removed the brake. Same problem.
Either the chain is way to tight or it's not getting oil. You could also apply air pressure to hole in bar to make sure it's clear.////Also the oil should drip out with sprocket off. Then when you replace sprocket oil should run down on gear and inturn supply oil to blade.
Sep 26, 2010 | McCulloch Garden
MAC 7-38 chainsaw stalls when you open the throttle. Any ideas?
We are talking about an electric chain saw ?
I would say you are not getting oil to the bar chain sprocket. Do you have enough bar oil in it ?
Feb 01, 2010 | McCulloch 10" Electric Pole / Chain Saw
Chainsaw won't stay running at full throttle
15 years old...
One cause to look in too is a leaking seal around the crank, this is causing a vacuum leak.
Hope this tip helps.
R/
David
Jan 27, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My McCulloch Electric Chainsaw model 450s_15 runs for a few minutes then quits. Does this saw have some type of thermal protector? If not is there any idea what may be causing this malfunction
Remove the bar and chain. Does the motor run and not quit? If not, inspect the motor for sawdust plugging the vents and check the brushes for condition and length. If runs ok, check the side port for oil coming out. If ok, clean all of the holes in the drive end of the bar including the two small holes that pass oil to the chain slot. Use compressed air if available. Also, clean the chain slot all around. Oil the sprocket tip if the bar has one. Adjust the chain so that it moves freely, but doesn't droop from the bar.
Aug 06, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Unit works but chain stops when pressure applyed, what oil goes resevior.
Does the motor continue to run when chain stops? Electric saws usually don't have a clutch, so I would look for badly-worn chain sprocket, or a possible sheared key in the sprocket hub, or a loose mounting nut. Remove the chain and bar, try to turn the sprocket by hand (wear good gloves). There may be some type of overload clutch built into the sprocket.
May 09, 2009 | McCulloch 10" Electric Pole / Chain Saw
I just bought my McCulloch Electric Saw Model MCC1514 yesterday (4-13-09)at Ace Hardware, Mesquite, NV. I used it for the first time today. I filled it with Chain, Bar, and Sprocket Oil. All of the oil...
If the fill plug for the oil was tight, and no oil was leaking out of it, then you need to return it to Ace, cause if it's leaking out of the drip hole or the case, it is a factory problem, not yours. Hope you don't have to drive too far. Rick
Apr 14, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
91 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
