Error code 5d
The water is draining slowly and not completely and this code comes up 5d
  • 3 more comments
  • Anonymous Dec 29, 2007
    code 5d showed up. We waited for few minutes but nothing was happening. Then we pressed the Power button and the code stayed, but the washer ended the cycle. We powered it back on and started the new cycle and all was well after that.
  • Debbie13 Jan 27, 2008
    error code 5d. I've had the same problem with it not draining and having to turn it off and then back on to finish the cycle. What is the solution?
  • Abbasy Apr 14, 2008
    My machine showed error code "Sd" look like "5d": the machine drain well but does not spin, if I reset then select "Drain & Spin" cycle, the same error code appears again when it tries to spin but can not spin.
  • Anonymous May 09, 2008
    the clothes were still wet and the machine was unlocked but had the 5d code
  • arbonnefixya Mar 12, 2009
    whirlpool cabrio 5d error. will not drain or complete cycle. agggh!
The error code is not 5 D it is "S" as in Sierra d. The letters stand for Slow Drain. I had this code and it was fixed in 5 minutes or less. Simply remove the bottom panel from the front of the washer. In the lower right hand corner, there is a tray to catch any items that may slip past the boot on the door seal. Slide this tray out and clean it. You will be amazed at what is in there...money, bobby pins, socks. Reassembe the washer and presto. Fixed.
Posted on Apr 10, 2010
I had this same issue and all I could find was that it had something to do with suds and that it may not be draining correctly. I found that there was clothing in the tub section behind the metal screen. This caused my washer to try and run each direction but dever fully spun.
Good luck
Posted on Apr 16, 2009
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Error code 5d or f-21
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Oct 16, 2012 | Whirlpool Duet GHW9150P Front Load Washer
5d error code
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi i have a Whirlpool sport duet and after a few minutes it stops going and Sd or 5d comes out on the small screen. What does this mean? Does not say in the owners manuel
Hi
Daniel
Aug 04, 2011 | Washing Machines
5d keeps popping up on my washer & the clothes are soaked, its not spinning the water out.
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Washing Machines
Error code 5d -- what does this mean?
Hi
Error code SD or 5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore HE2 Plus Front Load Washer
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
4. Check/clean drain pump filter of foreign objects.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer indicates "5d"...
take bottom panel off should be 3 to 4 screws and will come off then you will see your drain pump in the middle in the center with a plastick cap you can take off. before you take off get plenty of towels ready because water will come out try leaning unit back until you dont have to hold it then take cap off and clear any debree you find and put cap back on and try running again offen to much debree can damage pump and might need to be replaced!
Feb 23, 2009 | Whirlpool WFW8300SW
Washing Machines Logo
3,203 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
