Creative Labs Zen Digital Media Player Logo
Posted on Oct 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PMC Firmware Corrupted, Try to install new firmware 1.03, can't
Got error 1 when turn on PMC, Get error 2 when connect by USB. Look into manual, it stated that firmware corrupted need to reinstall. Download V.1.03. PMC was connected, but during the installing step, program keep asking to connect PMC. Can't do anything. Please help
Anonymous
Level 3:
  • Master 496 Answers
  • Posted on Oct 07, 2009
Anonymous
Master
Level 3:
Answers
496
Questions
Helped
122416
Points
1299
Remove the device then runn the program and when it asks you to connect the device then connect it if that doesnt work please post an aditional comment and i'll see if i can help you out more :)
  • Anonymous Jul 09, 2013
    You know my player have a large screen but it doesn't play till now without driver
madison smith
Level 2:
Novelist:
Habit-Forming:
  • Expert 88 Answers
  • Posted on Aug 04, 2020
madison smith
Expert
Level 2:
Novelist:
Habit-Forming:
Answers
88
Questions
23
Helped
32815
Points
331
In order to resolve the matter at first, you have to know more about the error code in detail. Generally Driver Corrupted Expool Windows 10 occurs when users have issue with the device driver on windows that indicates that the system attempted to access invalid memory at a process IRQL that was too high .So, in order to get rid of this annoying error message, you can try the following methods which mentioned below.
Steps To Fix Windows 10 Driver Corrupted Expool Error
Steps 1: Update the Obsolete Windows Drivers or Managers
Steps 2: Reset the Windows 10
Steps 3:Try the Anti-virus, Anti-adware, or Anti-spyware Tool
You need to try the anti-virus, anti-spyware, or anti-adware tool to scan your PC.
I hope all the above methods will help to Fix Driver Corrupted Expool Windows 10 .
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
742
Points
I found the solution to this problem. You MUST be using Windows Media Player 10. Also, uninstall Microsoft User Driver pack found in add or remove programs.
After getting your Windows XP machine back to Media Player 10 you can then click the upgrade button. You may need to uninstall the Portable Media Center from Device manager if your plugged it in at the wrong time.
Solution: Have Windows Media Player 10, nothing higher or lower, and uninstall User driver pack.
Error 49.ff04 for hp cp 3525x
Normally caused by firmware.
This error can be caused by corrupted print
jobs, software applications issues, nonproduct
specific printer drivers, poor-quality
USB or network cables, bad network
connections or incorrect configurations,
invalid firmware operations, or unsupported
accessories.
Power cycle the printer. Try printing from a different application. If the error doesn't come back, it could have been caused by the other application. If it does return and you are sure that your cables(USB or network) are good, you will probably have to upgrade the firmware.
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
tip
ILo Mp3 Player Help is Here
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
on Sep 13, 2008 • iLO (2 GB) MP3 Player
3helpful
2answers
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
1helpful
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
IXUS 80 can you help...photos won't download.."COMMUNICATION ERROR"
This can be due to various reasons
1)The driver is corrupted: The camera's drivermay be corrupted. Uninstall the driver and any software and then connect the camera to the PC and then re-install the software.
OR
2)The USB cable might be faulty. Remove the memory card from the cam and try using a USB card reader(You can get one for 5$) and see if works. If it does may be then its time to buy a new USB cable for your cam.
3)Last but not least the cam's firware may been corrupted. Its pretty easy to flash the firmware so we can try it. Let me know if the above solutions worked or not so that we can try the firmware update
Just stopped working
-Tha Mp3 Doctor
Cannot download
Make sure the lock/hold is not engaged
-Tha Mp3 Doctor
Ilo won't turn on.....
1helpful
2answers
Incorrect Format Please Reformat the Player
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
  3. Download the correct Firmware
    1. Click here to download the ILO 116 Firmware
  4. Click Open to initiate the download
  5. Double click on the ILO or Siren folder icon. There will be 14 icons.
  6. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  7. Then click Run - this will open the Install Wizard.
  8. The Install Wizard has the instructions on the screen as you go through it.
  9. Once the firmware has installed, please click the Start menu, then Programs.
  10. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
