Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Dryer not getting hot
I have had the heating element changed 2 times and now it's out again. What could be making it go out that the service man is missing? This is costing me a lot of money.
  • happylucky Dec 22, 2007
    Is this the stats and can I use a meter and a heat source to see if it is opening and closing?
    Champion:
  • 249 Answers
It may not be the element it could the stats
Posted on Dec 21, 2007
  • eamonn close Dec 22, 2007
    using a heat source could damage the stats, if they get too much heat they could stay open.Check them with a Ohm Meter when cold! you should get '000' if there ok ,or the needle should shoot up depending on which meter you have!.disconnect and mark wires before test.
  • eamonn close Feb 23, 2008
    why did you not rate me
My dryer doesn't get hot?where can i buy a heating element.
in your local phone directory look for comercial dryer parts supply give them the make and model the yr and ask them to order you a new heating element but make sure its your element first as there a re several safe relays that can blow first some times its more cost effective to have it looked at by a service man first most companys in your local paper do free quotes i would try there first
Jul 03, 2010 | Estate EED4300TQ Electric Dryer
Dryer air will not get hot...symbol for drying and cooling on at
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Dec 14, 2009 | LG DLE5977 Electric Dryer
Dryer not heating up. Vent is clear. Hear a clip but not getting hot MDGT3360
Nov 22, 2009 | Dryers
Wont get hot
Nov 18, 2009 | Maytag PYE2300AY Electric Dryer
DRYER NOT GETTING HOT
Nov 05, 2009 | LG DLE5955 Dryer
Miele Tumble dryer will not produce heat .
Oct 14, 2009 | Dryers
No heat in tumble dryer
Oct 06, 2009 | Dryers
Dryer isn't getting hot
Sep 13, 2009 | Dryers
Dryer doesn't throw hot air
Sep 12, 2009 | Speed Queen AGS68AWF Gas Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Oct 11, 2007 | Roper REX4634KQ Electric Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
