Question about Texas Instruments TI-30 XIIS Calculator
Where is the x cubed button at - Texas Instruments TI-30 XIIS Calculator
  • Texas Instru... Master
  • 7,993 Answers
To raise a number to the third power, use the general power key. It has the form of a caret [^].
Cube of 4 : 4 [^]3 [ENTER] gives 64.
Hope it helps.
Posted on Oct 03, 2009
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Why am I getting crushed ice when I requested cubes
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
Is there a reset button on the cube?
Unfortunately, the cube does not have a reset button. The way to reboot it is to remove the batteries and put them back in.
Jun 29, 2013 | Vtech Alphabet Activity Cube
Why can't I select cubed ice on my ge monogram fridge, all of the other buttons work fine.
the reason for this problem is a jam of ice inside the ice bin that will not let the knives that crush the cubes,and cant release to let cubes go by uncrushed,remove the ice bin,put the remaining cubes in a bucket,or toss,then check the ice auger in the bin and if theres a build-up of ice melt it with hot water,then thoroughly dry it,then replace this unit into the freezer,but do not use it until its cold again from melting the ice jam,then resume the ice making cycle
Nov 24, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
My icemaker has stopped ejecting the frozen cubes. If I press the button under the front of the device it does go through the eject cycle and fill again normally but then when the cubes are frozen it will...
Since you can work it manually (with the button) it is probably what they call the fixer sensor p/n DA61-01800A. It must not be sensing that the ice cubes are "fixed"
Jul 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Jan 09, 2010 | Electrolux Refrigerators
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Cube root
http://answers.yahoo.com/question/index?qid=20071129202945AAOndt7
You can multiply a number by 1/3rd to get the cube root or
Under the MATH button, the fourth option down will give you cube root. Any n root beyond that will require the x^(1/n) method.
Feb 12, 2009 | Texas Instruments TI-83 Plus Calculator
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Texas Instruments TI-30 XIIS Calculator Logo
89 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
