Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Seeing doubles then a red and green bar shows up on top and bottom
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
This is called a convergence problem.
This set uses two convergence IC'S---either STK-392-110 OR STK-392-150 (THEY are both the same but the 150 is a higher current device and lasts longer.)
The reason they fail is simple. They are black and about 2 1/2 inches wide X 1 1/2 inches tall and located on two metal heat sinks side by side--each has 18 pins--the back of each chip is metal--a white grease (called heat sink compound) is applied to each chip to transfer heat quickly--after several years the grease dries out and one of them reaches a point where it does not move the heat to the metal fast enough---the chip fails.
You can buy both chips (a pair) on Ebay for less than 14 dollars plus shipping (the chips will have the STK number printed on them in white.)
If you can do this repair yourself you can save a lot of money--most shops charge 300-400 for this type of repair---I have done hundreds of them and here charge 200-250 for this repair.
If you cannot do the repair--shop around your area and find someone who can do it right in your home--if they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
Usually just both chips need to be replaced, sometimes there may be a burnt or discolored resistor around them that also needs to be replaced.
AFTER the chips are replaced and the set adjusted with the remote---you should not have this problem for 5-8 years......
If you need more information or have questions reply to this posting here and I will help you--I am here to help people.
Regards, SD TECH
Posted on Oct 03, 2009
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
RED AND GREEN DOUBLE AND BLUR PICTURE HELP PLEASE
You have a convergence problem. Components are shorted out and must be replaced. Unless you're a technician, there's really nothing you can do at this point.
C-Dog
Feb 03, 2008 | JVC AV-56WP74 56" Rear Projection...
47wx42 - wavy red and green "bars" on top and bottom of screen
Replacing the two STK392-110 ICs didn't do it for me. But you can try. I am experiencing the same problem, and it appears that is not possible to correct the problem with the ajustments in Service Mode. Please let me know if you find a solution to this problem. TIA.
Aug 30, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
