Question about Sony Audio Players & Recorders
CD changer Sony HCD RX70 does not work or open anymore: ERROR
CD changer Sony Stereo HCD RX70
doesn't open, play or do anything anymore. Seems like the loading casette (for one of the three CD's) is stuck upwards as if a cd would be in there playing... Nothing in de CD player works anymore: lights ar all burning... (Okey it's an old stereo, but nostalgicly seen: damn!)
  • 16 Answers
SOURCE: problem with stereo playing cds
I'd be interested to know the brand, but you could try this:
(Assuming your CD player has only a standby button, not a full On/off button). Unplug the CD player from the mains. Leave for 30 seconds. Connect to mains and press eject as early as possible. Hopefully, this will allow the system to eject the CD before it starts trying to spin it.
Ultimately though, if it plays but won't open, it's likely to be a cog / gear on the drawer that has failed rather than some software fault as the CD plays.
Repair may not really be economical - depends on brand / value etc. If the disc is more important than the player you might end up attacking it....
Posted on Jan 15, 2008
  • 38 Answers
SOURCE: Can not load or Eject DVD
Be sure NOT to load any CD+ -R,CD+-RW or DVD+-R,DVD+-RW to this unit.
Try to load up a standard CD see if there is audio first. If so,try a good(not scratches) dvd movie.If you have tried both and still not working.You need this unit to be repair or buy a new one!
Joe
Posted on Feb 04, 2008
Maanita
  • 1142 Answers
SOURCE: Vostro laptop dvd/cd player not seen by system.
1.go to bios by pressing f2 key on dell logo
set num lock caps lock scroll lock on
press alt + e
press alt + f
press esc twice
2.
Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Posted on Mar 14, 2008
SOURCE: 6 cd changer mustang stereo
How do you manually eject the cds? I put in a new cd and it went in and does not recognize it and says slot is empty and now none of my cd's work....please help///
Posted on Nov 21, 2008
  • 60 Answers
SOURCE: CD Error on Stereo (Not a code issue)
I have seen this a bunch of times always with the same result, take it to a audio repair facility, the sterio has a bad internal circut. No external "quick fix" that i know of
Posted on Nov 22, 2008
For the(Technics Compact Disc Changer SL-MC59,60+1 CD Changer/quick change system)The equalizer is working,the control stereo Reciever is working but,the compact disc changer itself will not work. It...
if you can get to the laser eye take a paper towel or tissue paper soak in rubbing achole and clean the eye if you cant reach it or it is hidden in the mechinism get a disc cleaner and run that in the system it sounds like the laser eye is dirty i do it to my cd player all the time when it can't read the disc
Dec 21, 2012 | Audio Players & Recorders
Carousel does not turnsony 60 cd changer hcd-mg110
Hi Yam_man_dan, I have the same problem with my stereo. How do I check the gears? Do I remove the rotator that holds the CDs?
Dec 01, 2012 | Sony Audio Players & Recorders
SONY CDX 5090 - E 04 error message.
I have a Sony cdx 5090 car stereo, I don't have the manual for it. I need to know the wiring color codes for it to hook it up.
Aug 22, 2009 | Sony CDX-5090 CD Changer
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
CD changer problem disable play or reject CD function
I sould checkyou phone book to see if there is a bussiness that repairs car radios and cd players.
Other wise you should look into a new cd player at a local electronic store that sells car radios and cd players. The last option is to go to the dealer and order another one.
May 15, 2009 | 2007 Toyota Camry
Our sony hcd-hpz9 stereo will not allow the 5 disc changer to open. It will play disc 1 only. Any suggestions. It makes a rumbling noise. Is there a way to manually open the disc changer?
this is done by a belt drive. i have seen the belts get old and slip. try to gently pull the door open as you hit eject. If you get it to open and find that it will not fully open or close without assistance this is the problem.
Aug 30, 2008 | Sony Audio Players & Recorders
Sony rx70 3 cd changer
I also have exactly the same problem with the volume control. I was hoping to resolve the problem by doing some internal cleaning but seems like johanknopper tried it before.
I was thinking of buying a remote control separately as I lost mine in relocations. Found a second hand on-line but I am not sure if they all have the same frequency and if it works with mine.
Any Ideas?
Aug 24, 2008 | Sony MHC-RX70 Shelf System
DespLady
It is error message of HiFi when it finds problem in Tape Mechanism. Tape mechanism is stucked and needs to be reset. Open your HiFi and rotate the capstan wheel with finger and then try to power up.
Jul 20, 2008 | Sony MHC-GX450 CD Shelf System
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
171 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
