Question about Maytag Performa PAV2200
PAV2200 washer squeaks when it stops - Maytag Performa PAV2200
    President:
  • 1,304 Answers
This can be fixed with baby powder
more than likely its the brakes
Posted on Oct 03, 2009
Hi my washer will not drain or spin Please help
lid switch or pump 1st start washer is the washer agatating lift the lid if it stops you need to ck the water pump all wasers need to drain the water befor thay will drain
Jun 24, 2011 | Maytag Performa PAV2200
Our maytag performa top load washer PAV2200 stopped in the middle of wash cycle and we heard a loud pop and then smelled burning rubber. My husband has pulled the belt off the bottom and its still in one...
Check the drain hose from the drum to the pump assembly. Alternativly look for the large capacitor that should be mounted to the internal framwork of the machine, see if has popped. They can make quite a bang when they go,
Jun 20, 2010 | Maytag Performa PAV2200
Squeaks when agitating
if its an old unit it is most likely your transmission time to get a new one before it stops agitating at all.
Apr 16, 2010 | Maytag Performa PAV2200
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Spin cycle
Ok,first off this machine has a clutch brake assembly on it that is known for sticking.It will sometimes hit a very high squeak at the last spin as it stops.Ive come up with the solution to fix this but Id have alot of trouble explaining it this way .Please contact me and assist you in depth any time you need.  archieferrarini@yahoo.com
May 15, 2008 | Maytag Performa PAV2200
Washer make a loud squeak when the spinning stops
This is a very com. prob. with this unit. its is expensive to fix and will come right back when humid out best thing to do is just put up with it.
Apr 06, 2008 | Washing Machines
Maytag top loader 5+years old
Sounds like a water pump problem. Please specify the exact model, and I will link you to the disassembly instructions.
Jan 08, 2008 | Maytag Performa PAV2200
Washing machine maytag performa
This problem is normally attributed to a combination of two things: A worn out snubber ring, and a worn brake assembly.
The snubber ring assembly is a white teflon ring that sits under the wash tub at the base (called the milk stool, because it looks like an upside down milk stool).  The entire wash tub assembly will rest on the snubber as it helps get rid of vibration while the tub agitates and spins.  When the snubber starts to wear down, you will notice an increase in tub vibration during the spin cycle and it will sometimes begin to squeak. NOTE: YOU CANNOT OIL THE SNUBBER! DOING SO CAN CAUSE MORE DAMAGE.
The brake assembly is mounted between the pulley wheel and transmission under the washer.  As the brake assembly ages, the pad (which is mounted along the rim of a metal disc) begins to glaze over.  As it glazes, it will also squeak and cause the sudden "slamming" to a stop.  The glazing, coupled with humidity in the air can make this condition worse.
Both problems occur normally with this model washer and can be attributed to normal wear and tear.  I recommend replacing the brake assembly and snubber at the same time.  You will need, however, a special Maytag brake removal tool and spring removal tool if you decide to attempt this repair yourself (it is possible to accomplish this without the aid of a repairman).  Let me know if you need further assistance.  CAUTION: THERE IS A 200 LB COMPRESSED SPRING UNDER THE BRAKE HOUSING.  ATTEMPTING TO REMOVE THE COVER WITHOUT THE BRAKE REMOVAL TOOL CAN BE DANGEROUS.
Oct 30, 2007 | Maytag Performa PAV2200
Maytag Washer
Is the machine belt driven? Look under the washer and see if the belt is laying on the floor. If so, just get a new belt.
Dec 04, 2006 | Maytag Performa PAV2200
Washing Machines Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
