Question about Wolverine FlashPac 7000 120 GB USB 2.0 Hard Drive
I have the 80 gb version and need to reformat it. I reformated it on my xp computer and I guess that it made it a NTFS drive. I have tried to format it to FAT32 from the comand line and have tried swissknife the cmd process tell me that the disk size is too large and the swissknife just crashes when I select the Wolverine. Will exFAT on a Vista OS work?
    President:
  • 281 Answers
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Jan 30, 2010
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
How to reformat a external hard drive to ntsf
Insert the USB hard drive into the PC's USB port.
Go to Control Panel - Administratve Tools - Compurt Management - click on Disk Management - scroll down and click on the external haqrd drive, delete the HPFS partition (this is the MAC file system), create a new partition NTFS - format this partition.
If you want to use this external dirve to exchange data between the PC and the MAC the format this hard drive in FAT32.
The MAC can read and write files in FAT32.
Apr 16, 2012 | MicroNet Technology miniMate MM80 80 GB...
My iomega professional hard drive (500gb) that I bought last year won't work on my new computer. It shows up under devices but I can't save anything to it. It worked fine on my macbook, but I now have a...
I would try recommending formatting the drive this will take everything on it off. However it probably needs to be reformatted to ntfs. On the right in the disk management you should be able to see how it is formatted. For xp and up to need that to be ntfs
Mar 06, 2011 | Iomega Professional 500 GB FireWire 400...
Why can't I copy larger files than 4 maybe 5GB to my passport WD? Is there a quick way how I can change this?
Your disk is formatted using FAT32 file system. FAT32 has a maximum single file size of 4GB. Reformat your drive using NTFS file system to enable file saving larger than 4GB.
To reformat the drive:
-insert external drive
- open "My Computer", point your mouse over the drive letter of your external drive, right-click and select "Format". Select NTFS from drop-down menu under "File System".
-click "Start" button
Please note that all data will be deleted so please backup your files before formatting the drive.
Aug 25, 2010 | Western Digital Passport WDXML800UE...
I need to reformat my 80 GB Firelite
whats the OS you are using? if you are on Xp. go in to my computer. right click on the external drive ( the drive name will depend on you device) click format.
May 04, 2010 | SmartDisk FireLite 80 GB Hard Drive
I bought a 80 GB portable HDD but when I connect it to the computer running on Windows 98, the computer does not recognize the drive. Please advise what to do? The supplier did not provide any driver...
Win 98 does not support plug & Play USB devices unless the drivers are installed. Xp how ever does. you need to install the drivers to be able to used the device in win 98. since you did not get a driver cd, best would be to download the drive from the net. if you abl to give me more details of the device, i would be able to find the driver.
Mar 19, 2009 | Electronics - Others
Reformating in NTFS
this is the option comes when you boot your system through a bootable xp disc
Nov 27, 2008 | Computers & Internet
I reformated my hard drive and I cant load windows
1.Make sure the hard drive is installed correct and the bios found it.
2.In bios you have to put the cd/dvd as first boot and the hdd at second.
3.Load the original windows xp disk and restart saving changes in bios.
4.When prompt to pres any key do so.
5.Continue setup as new install. (if a miss one excuse as im thinking the step)
a.Enter continue
b.F8 I agree
c.d delete
d.enter sure
e.L delete
f. C create partition
g.Enter create
h.Enter Install
I.NTFS Quick Enter
Lets windows format copy some file and make a restart.
Keep windows setup all the way.
Install drivers and that it.
Let us know thanks.....Hope this help....
Sep 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
WD device in XP reformatting drive to NTFS
ther is no probla m with ntfs formating just do the ntfs formating then it will work fine your files correct
Jul 20, 2008 | Western Digital My Book Essential Edition...
SanDisk Micro Cruzer reduced from 2.0 GB to 1.0 MB when reformated
Make sure you check to see if the File System is FAT32 instead of FAT or NTFS, this way you can have your 2GB back.
Try reformatting using FAT32.
Dec 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Wolverine FlashPac 7000 120 GB USB 2.0 Hard Drive Logo
286 people viewed this question
Top Wolverine Computers & Internet Experts
David Payne
David Payne
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
