Question about Plumbing
Well water comes out brown, low pressure
Well water comes out a brownish color from all faucets, water pressure is very low, happened sort of suddenly.
    Top Expert:
  • 12,173 Answers
Picking up sediment[silt-mud-dirt] holding tank probably bottom filled with it turn off well and flush out holding and hot water tank if one and install inline filter after holding tank to stop any further debris getting into water lines your pump is sucking the silt up from the well usually happens to places that have had really bad rain season or flooding
Posted on Oct 07, 2009
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
We have a problem with not having good water pressure. Is there a way to adjust pressure?
is low pressure limited to just one particular faucet...lavatory, kitchen, etc...? is pressure low on both hot and cold? if so, the first thing to check is the aerator..where water come out of spout..if all fixtures are have low pressure..you could get a water pressure gauge at hm depot..or local hardware store and check incoming house pressure at outside hosebid..you mite have a faulty pressure reducing valve usually located at owner side of city water meter..
Oct 30, 2013 | Belle Foret Plumbing
Hello, I replaced the seats and springs in my faucet Delta Leland 2578 and now my water pressure is low. So I thought it was the stem unit assembly because it had a lot of deposits on it so I replaced...
it would only be aerator if hot and cold were low..what happened is when u shut angle stop off on hot water to replace assmbly..the washer on angle stop separated and is blocking the supply
Nov 21, 2010 | Delta Faucet 2578-278 Leland Series...
LOW PRESSURE HOT WATER SIDE
Disassemble the hot water valve. Look for calcium or any other materials, and clean. If you see white plastic particles, then it's probably from your water heater down tube
Jul 19, 2010 | Moen 2 Handle Lavatory Without Drain...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
The pressure in my Delta faucet is suddenly low. The pressure throughout the rest of the house is fine. What is wrong? I replaced several pieces of the faucet but nothing worked.
Take the hoses off on the bottom of the faucet and blow air back through the faucet. Dirt can plug up the small openings right where the water enters the faucet. By the way I hope you checked the areator on the end of the spout, Dirt can plug that up also.
Nov 11, 2009 | Delta 2402 Classic Single Handle Kitchen...
No hot water comes out of faucet
clogged mixer valve. disassemble and you may find a small prticle preventing the valve vrom shifting.
Dec 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | American Standard Plumbing
Plumbing Logo
658 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
