Question about Kenmore 78570 / 78571 / 78572 / 78574 / 78579 Gas Kitchen Range
Alram going off F-1
Replaced the ignitor but the alarm is going off displaying F-1 what to do?
  • 146 Answers
Disconnect for 30 seconds - if display reappears - replace control board. You either have a Shorted keypad, a Analog to Digital Failure, or a Safety flip flop. In any case all of these problems require a control board replacement. A defective control board is the only reason for an F1 code.
Posted on Dec 21, 2007
I have a UND. MSG. alarm on my Galaxy 5000
Did you get an answer for this question?
Apr 08, 2014 | APC Computers & Internet
My 2000 grand vitara alram wont stop going off what can I do to stop it
a lot of times car alarms go off when they since a voltage drop in the vehicles battery test or replace cars battery
Jun 01, 2012 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
Low fuel alram and fuel gauge malfunction
Sending unit is faulty. Check for damaged wiring to the fuel pump. If wiring is good, the sending unit needs replacing.
Dec 19, 2017 | 2005 Chevrolet Colorado
My ford mondeo lx petrol 98' alarm goes off, sometimes more than once i have to keep going to the parking lot to open and close the door only for the alarm to stop but after some time it goes off again.
Your problem is most likely the central locking / alram switch fitted aroun the door lock inside the door void. Try using the passenger door to lock / unlock. If this stops the alarm triggering then you need to replace the switch behind the lock in the drivers door.
Feb 16, 2011 | Code-Alarm Code Alarm Transponder
Can i by bypass my car alram
The car alarm on your 2000 Windstar minivan is wired into your van's battery. When you are making a repair to your car such as a battery change out your alarm can go off. You can easily disable the Windstar's car alarm by disconnecting the battery from the alarm. The battery is connected to the Windstar battery's negative terminal. Disconnecting the terminal from the battery will disable the alarm.
  • Socket wrench
  1. 1 Raise the hood of the Windstar to gain access to the battery.
  2. 2 Loosen the negative battery terminal labeled with a "-" with a socket wrench.
  3. 3 Disconnect the terminal from the battery to disable the alarm system.
Dec 12, 2010 | 1999 Ford Windstar
The battery went dead. jump starting caused alarm to go off. How do you turn alarm off?
HI after you get it started you will need to turn the car off and use your remote to lock and unlock your doors this shuld reset the alram system.
Aug 30, 2010 | 2004 Kia Optima
Battery dead
You need to hook the alarm back up and do a reset on the car.
Here is how you do it.
1) Turn factory original key to "ON" position for 5 seconds
2) Turn key to "OFF" position.
3) Repeat 1 and 2 again. Do it twice.
4) This should reset the computer to the chip inside the key.
If that didn't work,You will need to have the codes downloaded at the dealer.
Aug 08, 2009 | 1995 Nissan Maxima
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
Car wont start
i had this problem with mine just opening the door with the key seems to disengage the alarm so that the engine will start again
Sep 22, 2008 | 1996 Chrysler LHS
Kenmore 78570 / 78571 / 78572 / 78574 / 78579 Gas Kitchen Range Logo
107 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
