Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
In the fridge the setting panel green lights keep flashing fisher paykel
    Sergeant:
    Champion:
  • 323 Answers
If you leave the door open too long it will flash a warning
close the door and make sure it is tight .
if this doesnt work , just unplug the fridge and plug back in aftera couple of seconds, this will reset the unit and should solve your flashing problem
Posted on Oct 03, 2009
I have a fisher and paykel fridge freezer - the problem being once fridge is opened it keeps beeping and on the front panel it shows a spanner flashing
sounds like the door opening switch must stick. find the switch, should be visible near the hinge area of the fridge and spray some wd-40 into the housing. that might work!
Jul 03, 2016 | Fisher and Paykel Refrigerators
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
Temperature light at back of fridge randomly goes from red/green and the temperature in the fridge does not appear to be stable?
on a fisher paykel I would call them direct, their help desk can walk you through some checks to see what the error is... if I needed service on this unit I would use who they suggest.. because if the servicer does not have access to the factory on FP HE IS GOING TO BE GUESSING WITH YOUR POCKETBOOK in hand... we work on FP everyday and we call often....... I hope this helps.... ken
Sep 29, 2014 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fridge Freezer E402B not functioning properly.Solid red error light,with green light flashing up and dwn when push the = button.No air circulation to fridge,compressor seems to continious,also fridge
Natasha try this:
turn off the fridge's settings.
pull the power cord from the wall outlet
open the doors and keep them so for a few hours.
before these, take out the most perishable and keep in cool place.
after a few hours you may see a puddle of water under the fridge. clean the water and vaccum the fridge underneath and behind.
now reconnect power and set at recommended level. goodluck!
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Dec 21, 2007 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
243 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
