Question about Kenmore Kitchen Ranges
I have 2 burners on my electric stove that don't work. It looks like they have sorted the wire connectors out. Can I get parts to fix this?
    President:
  • 1,304 Answers
Yes but i would do volatge checks on the robert shaws or selector w=switches before i bout burners
Posted on Oct 06, 2009
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
2 hobs on my electric cooker are not working
? 2:34
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
? 6:52
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
My whirlpool electric stove a burner don't work l
my whirlpool electric stove top two big buner is not working
Nov 28, 2012 | Kitchen Ranges
Replaced a burner and it won't come on
may have also burned the wires going to it turn off power or unplug then open up the top and look around , if you feel cofortable with hot wires and have a tester you could removed the wires from that burner isolate them so that they don't short out on the stove then turn on the power to that burner checking the wires for voltage should have 120 + or - a few is ok , if no powe r work back from there till you do find power
Dec 09, 2011 | Hotpoint RB757 Electric Kitchen Range
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
Feb 12, 2011 | Microwave Ovens
I have a Frigidaire electric range with four burners. One is working perfectly, one is not working at all and 2 are working at reduced power. How should I go about repair? Is it likely that the burners...
First, I'm not a Frigidaire tech. I have worked on electrical stoves. BUT since there are High voltage and High current used in stoves I strongly recommend you have a qualified tech service your equipment.
*** The following is for information only ***
* Looking at your elements, it's not the plug in style seen on old 1960's ranges. (yeah, I'm old) The later models use special plugs and newer units are dedicated elements specific to the brand. Replacements, (if found) must be exact. I found this link:
https://c.searspartsdirect.com/lis_png/PLDM/R0102071-00004.png
* Again, check your warranty and call for service.
* Replacing your element(s) may be only part of the problem. I've found bad wires, shorted wires, burnt terminals, cracked connectors, and the most common is rusted out parts. You will need to replace everything that looks remotely bad as they will fail when powered up again. But at this level of damage, it may be better to replace the stove.
Aloha, ukeboy57
Feb 11, 2018 | Frigidaire FEF326 Electric Kitchen Range
I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Feb 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
One of the burner does not work on my electric Kenmore stove.
the eazy answer is its the burner.i only say that because on most service calls with your complaint it dose indeed end up being the burner.but before i come to that conclusion i do check the out put of that burners switch.if has 220 volt output then its the burner,even tho if you look at the wiring diagram it will show a limiter before it gets to the burner but that part is built in to the switch and is not replacable on its own.so then use volt meter take a look at your wiring diagram .look on that diagram and decide which wires are leaving the questioned switch that controls your bad burner .place your probes on those wires again if reads 220 volts replace the burner. i hope this helps .God bless ,tom
Jan 04, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
My whirlpool cooktop front right radiant burner stoped working
Hi
You have to remove the old one first by disconnecting the wire teminals and the fixing screws. Remember to disconnect the power before starting work,
You can get the parts from www.pcappliancerepair.com/whirlpool-range-oven.php
Hope this gets you sorted.
Oct 21, 2008 | Stoves Sterling 1100E Stainless Steel...
Ge range
If the ceramic ring you're talking about is around the far outside of the element, then it being broken isn't a big deal (as long as pieces aren't missing). Its just an insulator.
If the knob is stripped, how are you turning the burner on? Are you sure the problem is the element and not the knob?
Either way, since your "friend" cut the wire, the element is not going to work properly. The crimp connections are designed to be removed and replaced, and the element is not going to come with any additional parts. Go to Radio Shack or an auto parts store and get a replacement crimp connector. You'll have to strip and recrimp a connector on the wire your friend cut. The wire may not be long enough now, though, so you'll have to twist the element while installing it so that the wire will reach. This should be fine as there's plenty of room to spin the element around.
Oct 24, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
44 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
