Question about Moen 8306 Commercial Electronic Lavatory Faucetatory without drain ass
SCREW INSIDE BATHTUB FAUCET IS CORRODED.HOW DO I GET HANDLE OFF AND PART OUT TO REPAIR
    Sergeant:
  • 233 Answers
Go to the hardware store and ask for a small set of EZ out bits.
Then you can use a small drill for a 1/4" Deep hole.
This will allow the Ez out bit to grab and you can extract the screw easily.
Tip: Make sure the drill is smaller than the thread portion of the screw you are trying to remove. Roughly HALF the size so you do not drill through the sides. Then after a 1/4" deep hole is made. Take the Ez-out that will fit this hole and tap it a few times into that 1/4" hole to seat. The other end of the ez-out you can use socket, pliers or cresent wrench on.
Alternative: Grab a small punch and make a groove on top of the screw.
You can then tap the top groove counter clockwise and the screw should begin to turn with each tap. Be warned this will often damage the screw badly. But the trick is getting the corroded screw out anyway. Right? :)
Posted on Oct 05, 2009
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How to lift off the handle after the set screw is removed?
it may be corroded on to the square shaft
WD -40 or like type in the screw hole may help but I think a gentle prying with a flat bladed screw drive at the edge of the handle or brute force may be necessary
Nov 12, 2015 | Kohler K-14402-4A-SN Purist Single...
Water does not come out of the bathtub faucet, but the rest of the faucets throughout the house are just fine...what is going on... Help...
You need a new faucet. Try popping the cap off the center of knob. Then take the screw out pull knob and lok to see if the insides are stripped out.while handle is off try turning valve with pliers if it works you need a new knob if not bew faucet
Feb 21, 2015 | Plumbing
No--need info on removing handle from Moen 87485 single handle faucet. We have removed the plug button and set screw but the handle will not come off. The handle is corroded through--can it be force
Sometimes there's a small Allen screw on the handle cover. But most likely if you've removed the cap and screw beneath, it's just stuck and will take some jiggling and vertical force.
Jan 01, 2015 | Moen Plumbing
We have a 2 handle Delta faucet in our bathtub and one leaks. House is 25 years old all the information I can find on Delta is for the single handle type and information would be appreciated
nathanolsen1.gif It probably looks something like this basically front of handle has a cap pops up usually phillip screw after unscrewing that the handle will pull off if its real difficult you may need a handle puller or cut off the handle with saw and replace the stems may just need a gasket but if its that old i recommend buying a whole repair kit that includes handles, stems, seats and will include everything except the seat wrench.
Aug 27, 2011 | Home
I can't get the screw out of the handle of my delta single handle faucet to change the seats and springs. I think it must be stripped inside the handle.
In most cases you can use a self threading screw and screw it in the top of the stripped screw and slowly turn it out. Might have to use a tiny drill bit to pre drill first.
May 08, 2011 | Home
My lever on my single handle kohler shower faucet is very, very loose. How do I tighten the lever. I don't see any screws or place for an allen wrench
There should be a screw hidden under a cap. depending on the model/style it may be as small around as a pencil diameter or as large as a half dollar (the larger is most common on acrylic handles) Just gently pry this off and you should find a phillips screw underneath.
Feb 04, 2011 | Home
Moen 8306  Commercial Electronic Lavatory Faucetatory without drain ass Logo
186 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
