Question about HP w1907 LCD Monitor
Monitor totally blank
My monitor is properly connected to power supply and to the cpu . However, it will display for only a few seconds then turns totally blank. Light on the power switch remains on though.
    President:
  • 1,015 Answers
Verify that it is not the computer causing the issue by hooking a different computer up to the monitor or the computer to a different monitor. Test the power supply with a fluke meter and verify that it is giving the proper dc voltage(you will find the rating on the powersupply). If the power supply and the computer test good then it could be the inverter for the monitor.
Posted on Oct 03, 2009
  • 63 Answers
You have a power supply issue. Something is causing teh supply breaker to trip. You will need to find a local repair shop to pin point the issues.
My monitor is properly connected to power supply and to the cpu . However, it will display turns totally blank. Light off the power switch remains on though.
This is a common issue with the VA1912 units. The black screen is caused by a failure of the filter capacitors on the power supply board. You can replace the capacitors and the monitor will be as good as new. Here is a link to some information on the capacitors needed to build the power supply board.
http://www.ccl-la.com/catalog/product_info.php?products_id=90
Apr 14, 2013 | ViewSonic VA1912w 19" LCD Monitor
I have intex it-1703 monitor it displays for few seconds only
Bad power supply. The power supply capacitors charge up and then discharge in a very fast cycle. If the capacitor(s) bulge and fail, they can't keep the monitor lit. You can try to pry apart the monitor shell and look at the power supply. If you see bulged capacitor(s), that's the problem. Replacement capacitors are available at mouser.com.
Mar 30, 2013 | Computers & Internet
Its not showing anything but it has power
please check whether the VGA cable is properly connected to your monitor and CPU and check. it should work. if not try with another cable.VGA cable and Pin will be blue in colour
Feb 13, 2011 | ViewSonic VA703B LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
I have a HPw1907 monitor and it will turn on for about 2 seconds, and it turns off. The CPU is fine, just a problem with the monitor. Any way to fix this?
We have the same model of monitor and had the same problem few days ago. The monitor just goes black/turns off. I noticed that the power button has a yellow blinking light and cannot be turn on/off again using the power button. The CPU is working fine also. When I turn off the avr, the power button's light turns blue for a few second and you can hear a click sound from the back of the lcd before it totally turns off. My lcd monitor is over a year old now and is 110v or 220v capable. Mine was originally in a 220v, i just put it in 110v and the monitor was fixed.. Hope this can somehow fix your problem.
Aug 02, 2009 | HP w1907 LCD Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Screen problem with HP DV 9000
I think Your computer C.P.U. power supply unit is not working properly. because these type of problem occur when Power Supply Unit is not working properly.........
So Don't afraid at all just change your c.p.u. power supply unit with new one (it is not costly at all).
Mar 19, 2008 | Computers & Internet
HP w1907 LCD Monitor Logo
268 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
