Question about Jenn-Air JJW8130D Electric Single Oven
Jenn-air model svd48600p can't unlock door - Jenn-Air JJW8130D Electric Single Oven
  • tomdunlap867 Oct 03, 2009
    there is no lock lever on the door of the jenn-air model svd48600p , this is a digital display.there are no nobs to turn. the lock light is on in the display panel, and the door is locked. it has been more that 36 hours since I used the self-cleaning mode, so the oven is definitely cool
    I have a jenn-air model svd48600p I can't unlock the door after I used self cleaning function. this is a digital display unit, no knobs and levers, the other(expert) told me to move knobs and levers. Ithe oven was cleaned more than 36 hours ago so it is plenty cool. the lock lamp is on and the door is locked, and I can't open it, I tried power cycling it and is still on
  • 6,784 Answers
HI. You will need to check the wiring that links the door latch assembly to the actual control board. The main board controls the actions of the door latch mechanism during cleaning sessions and long bake periods on certain models. If this malfunction occurred after a self cleaning session, the temp sensor may have failed, causing the oven temp to reach far beyond the rated threshold, in return, welding the relay contacts together. This will suspend the door latch mech and prevent the control from initiating the UN-lock signal.
If you are sure that this didn't occur after a self cleaning session, i would suggest to unplug the unit for 5 minutes. after the five minutes are up, simply plug the unit in the appropriate socket once more, and power up. If you experience the same issue as before, this will confirm that the door lock latch mechanism has failed. it should be replaced in this case.
NOTE(If an over temp situation has occurred during a cleaning session, and the door would not unlock after the session, this will require you to replace the control board, lock mech and wiring harness contacts as well).
Posted on Oct 03, 2009
    Brigadier General:
  • 8,619 Answers
HI
Thanks for using FixYa. The lock indicator light must be in off position. This can take more than one hour. After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off after the door is unlocked. If the temperature knob is turned to off before the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this is the case, then return the temperature knob back to clean, unlock the door and turn the temperature knob in off position. If still you are not able to open the lock then it means that the lock motor might have failed. Use an insulated wire bending into the hook and slide from the right side and move the door to the right. It can also allow you to release the lock and open the door.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Both upper and lower oven elements won't heat beyond warm (100 degrees) Jenn-Air Model# SVD48600P
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 15, 2010 | Ovens
Jenn-air SVD48600P oven will not work / F3 error . I recently replace the expense control / clock unit on my oven because it would not heat. This was advice from repair person. Once replaced the over...
Hi jmhostetler9,
This F3 that keeps flashing on your oven is caused by a shorted or open oven temperature sensor (RTD). To fix this problem check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Dec 22, 2009 | Jenn-Air JJW8530C Expressions Collection...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Broke Glass door for Jenn-Air 701642K
Hi, Go to www.bellparts.com and tyoe in the model # located on a tag either around the door opening or around the bottom drawer.
I hope this helps you.
Vic
Jul 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
My oven Door fell off. it is a Jenn-Air JJW9530C
This is a known issue. The model number is JJW9530C. I have been browsing the internet trying to find stronger hinges but with no luck. It seems there are a lot of unhappy Jenn air owners. You are correct in your assumption that the door is to heavy for the hinges. I will post the websites for your review
http://www.ovensworld.com/jenn-air-jjw9530c-expressions-collection-electric-single-oven.html
Maybe if I could see the hinge I could fabricate a stronger stainless steel one for you
Apr 27, 2009 | Jenn-Air JJW9530C Stainless Steel Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Need a manual to operate five year old Jenn Aire wall oven
Jenn Aire model tag are usually at the opening of the door, or may have to pull unit out...be sure to check around the door before pulling out.
Jun 14, 2008 | Maytag MEW5527B Electric Single Oven
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air JJW8130D Electric Single Oven Logo
164 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
