Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
How do you fil up the spa wit water
I want to fill the spa with water from the pool. What button do I press?
  • 21 Answers
Do you have a jandy system?If so press spa fill in service mode till spa is full and place back in auto.
Posted on Oct 03, 2009
Spa emptyed into pool and the jets are still working what do I do to fill the spa again
If use a diverter to move the water from pool to spa and back and forth then you can use that to fill the pool which is what I suggest doing otherwise you would use your hose to start fresh unless there is plenty of pool water.
Rod
US Parts Center
888-521-6183
Mar 05, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Just opened the pool for the season. Heater not working. Screen shows RV1 and SSN (i think this is correct). Any suggestions??
I had the same problem I took the front cover off and used a wench to take off the gas jets they were filled with spider nests I cleaned each one out wit a large paper clip and put them back on and it worked
May 23, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
Just bought house with aqualink pool spa, one of our teenagers pushed the buttons, we dont know which one and the spa has emptied and the pool is full and we dont know how to get the water back in the spa...
You cannot drain the spa using the indoor controller, unless the valves out at the equipment are set wrong. go to the outside pannel and put the system in" service mode"(using the button on the left). then push the button on the right till it says "spa fill".There are 2 "accuators" (or automated valve turners) They are black rectangular boxes connected to the water valves. Use the toggle switches on the side to turn the vales to the correct positions. You want the pump to **** from the pool and return to the spa. Now turn on the filter pump and let it run till the spa is full. Put the system back in "auto mode" and you are done.
Oct 28, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I just cleaned out my Pentair FSN filter as I hve done several times before. I replaced the internal air bleed assembly from the factory piece (broken filter piece) to one with a screen from the pool...
it sounds like your valving for the return water is set wrong. check to make sure that some water will return to the spa when the pool is running. It's a valving problem more than it is a filter problem.
Aug 23, 2010 | Pentair Fns Plus 48 sqft De Pool Filter...
My jets on my topaz II won't shut off
maybe your filtration cycle is set to high.
check with your instruction manual on how to bring filtration cycle up and if showing FIL 8 or Fil C then this is the reason.
Is the spa up to temp? if not then spa is running all the time to try and heat.....
if not then may have a circuit board error or top side controller
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 12, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
When trying to set a cycle on the salt water system, three beeps sound when the up button is pressed. Ditto for the down button. I can't get past this to set a cycle. Any thoughts?
try unpluging and and wait a few minutes to reset.
If that does not work if your system is less than 2 years old and you have the receipt you can call intex for a free replacement
They will e-mail you a form fill it out and fax back to them
You will have a new unit at your door in a few days
Aug 05, 2010 | Intex Automatic Salt Water System for ...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Feb 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
No heat for the spa.
go to the heate and see if it tries to start and report back on any noises you hear or click or fans or is you smell gas
Jan 03, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
127 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
