Question about Bernina Sewing Machines
I was using a basting stitch and sewing along and the needle stopped --the plate moves the fabric forward but no needle up and down motion. Is this something I can fix?
  • 202 Answers
Hi this is a common problem with Berninas 930 - 1630. The problem is that there is a small pin that electromagnetically engages and disengages the needlebar when in basting stitch. If the basting stitch is not used much (or ever) the oil will harden or dirt will get in it and cause the small pin to stick. Therefore the needlebar will not engage. Possibly by softening it up with a blowdryer in the needlebar area (the slot in front) and tapping it etc. it might free up. Otherwise it jneeds to have a tech look at it. Its 50/50 whether it can be freed up from the outside. If a tech has to go to the inside and take it apart and clean it it could be more expensive. I always tell people to excersize their basting stitch. Use it or lose it. I hope yours will free up easilly. Time to have it serviced maybe. Good luck.
Rick
Bernina tech
Posted on Oct 08, 2009
How do I set 8900 for free motion quilting? D4S mode and QB-S foot
To do free motion quilting on most machines, install a darning foot or free motion quilting foot, drop the feed dogs, set the machine to straight stitch. (Because FMQ requires you to manually maneuver the fabric, stitch length is moot.) If your machine has the feature, setting it to Needle Down will also help. When you stop sewing, the needle will stop while penetrating the fabric. This prevents you from accidentally moving the fabric while trying to adjust before sewing again.
Free Motion Quilting Beginner Tutorial 1 of 4
Jan 11, 2017 | Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
Feed dog low.Notpulling.Checked setting for sewing/darning, it was set right. Tried levers, moved the basting stitch nob to L and R and...the needle bar jumped up like 5 inches, into the head.
Difficult to diagnose without the make/model. However, if it has a basting stitch, that could be one problem. Some machines with a basting stitch have a problem with it sticking and preventing the machine from working properly. Also sounds like perhaps the feed dogs are dropped for darning and are not pulling the fabric through the machine--or the stitch length is set too close to zero so the stitches are sewing in one place or on top of each other. Make sure the machine does not have a darning foot installed--the darning foot is shorter than standard feet so there is space between it and the needleplate. Also, some machines have the ability to increase/decrease the presser foot pressure that will affect the way fabric is moved through the machine.
Recommendation is take it for service.
Jan 07, 2016 | Sewing Machines
Fed dogs will not move fabric
hi, do a web search for feed dogs and put the make and mode lof your sewing machine in there along with the words how to adjust or how to repair....it should throw up loads of results
Jul 03, 2015 | Sewing Machines
How do I set for basting
Some compuerised machines will have a basting stitch programmed in, it may have a symbol like a dot then a long dash then another dot. This will give you a decent spaced basting stitch. On mechanical machines sometimes you can get a basting needle plate - you set up for the longest widest zigzag stitch and the tube on the plate makes one side of the zig not catch so you get a long straight stitch.
But if you are joining silky fine fabrics together, then needle and length of thread doubled is still the best way, takes a little longer but the fabrics won't creep and slip.
Oct 23, 2011 | Brother PS-1250 Pacesetter
How to set to baste
You would select a straight stitch and adjust stitch length to maximum length. And turn down the tension a little.
The Swiss Elnas had a basting plate that you used on a big wide zigzag and it would "miss" hooking the top and bottom threads together on one side so you ended up with a long straight stitch but with plenty of looseness to the seam.
But I've always found a needle and thread by hand is most effective, especially when attaching interlining to a silky fabric or velvet. Machine stitching would creep, but hand sewing would lie flat.
Apr 04, 2011 | Elna 2007 Mechanical Sewing Machine
E123@aol.comMy needle on my Bernina 1530 Inspiration just stopped going up and down whether I use the foot pedal or manually attempt to move the needle
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Mar 13, 2011 | Sewing Machines
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
Bernina 1090 Needle assembly stopped moving down
There is a spring loaded catch on the needle bar assembly. It is designed to keep the needle bar from going up and down on command for basting. That way it can take fewer stitches while basting. Anyway, over time, with lint build up, use and not enough oiling, the needle bar clamp release can stick. It is located in the machine cover and hard to get at. It is located right at the point where the needle bar clamp (middle of needle bar) is. It looks pointed on top and about 3/8" tall and SHOULD be able to move front to back (as you are sitting at the machine. If you want to fix it your self, lay the machine on it's back to see up into the needle bar area, you can also see through the threading slot as well.to oil it with SEWING MACHINE oil (read not 3 n1 oil) and try to work it front to back until it breaks free and play with it until it springs back every time you push it. I hope this helps.
Kent
Mar 21, 2009 | Bernina 1008
Sewing Machines Logo
347 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
