Question about Samsung CLP 300 Laser Printer
Paper jams. I can see no real jams but the printer stops and i have to take the sheet out to go on.
  • 68 Answers
Pull the paper tray out and try to clean the rubber feed roller with alcohol or water.
Posted on Oct 04, 2009
201.22 code
support lexmark com Has something to do with the cartridge not being installed properly. (Not a paper jam even though the second sheet jammed) Steps to follow are at the website.
Jun 04, 2014 | Lexmark MX310dn Monochrome Laser...
LexMark 5400 Series All-In-One Printer
To clear a paper jam:
  • Pull Carefully
    If the sheet of paper is visible at the output slot of the printer (in other word, it stopped on its way out of the printer), try pulling carefully on it. If it pulls smoothly and easily, then carefully pull it the rest of the way out. If there is resistance, then stop and go on to the next step.
  • Open the Cover
    Open the printer cover and wait (in the case of an inkjet printer) for the carriage to stop moving. Carefully, slowly pull out any paper that is caught there.
  • Take Care
    Do NOT pull paper out from where it was feeding into the printer (where the blank paper enters the device). The rollers on your printer may only go in one direction, and if you force them the wrong way, you could damage the machine.
Be careful of the following:
  • Laser Printers
    If you have a laser printer, be very careful when pulling out the paper -- laser printers can get hot.
  • Paper Shreds
    If any paper tore, either during the jam or while you were removing them, remove any appliances that you can (paper trays, etc.) and look for the shreds of paper. Try to make sure nothing has been left behind.
If you have frequent paper jams:
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
Goodluck..
Feb 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
    Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
    Oct 24, 2009 | OKI C5500n Printer
    My printer pulls in about 8 sheets of paper at once, shoots them through and then says there is a paper jam. There isn't a paper jam.
    It may think there is a jam because it expected lets say a single A4 and when it shot the paper through the sheets became separated a little so it looked longer than a sheet of A4.
    A real easy way on ensuring that you don't get too many of these situations is not to overload the feed tray. Also just before you put the paper in do the "desktop shuffle" separate it a little then tap the sheets back together on the table both top and side. Also never use paper that has been allowed to become damp in any way.
    If you found this information useful please click below
    Aug 12, 2009 | HP J3680 Officejet All In One Printer
    Hp photosmart 2410xi - paper won't feed properly through, jam
    Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
    Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
    Hp psc 1315 paper jam
    . Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    6.
    Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
    7.
    Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Problem
    Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
    To fix the paper Jam errors please try the following steps:
    1. Confirm that no foreign materials are inside the machine.
    2. Confirm that usable paper is set.
    3. Confirm that the paper is set properly.
    4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
    5. Disconnect the printer power cord as well as the printer cable form the printer.
    6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
    Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
    7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
    Regards
    Malik Khan
    Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
    Samsung CLP 300 Laser Printer Logo
    188 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    CheckitRight
    CheckitRight
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
