Question about Tools & Hardware - Others
I own a macallister COD1500WR router using 8 and 12mm dia collets (difficult to source metric cutters in the uk?), is it possible to upgrade collets to 1/4 - 1/2'' for the uk?
5 Suggested Answers
SOURCE: How does one change from one collet size to
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Posted on Apr 28, 2009
joboo1
  • 257 Answers
SOURCE: Need a 1/4 inch collet for a craftsman 315269210 router
Pssssssttt ( ya wanna know a secret?) When you buy a product from Sears, they make nothing. They have things made to their specs by other manufacturers. So what are the odds you searched a part number and came up with the exact same item made by somebody else? More interesting - Ryobi started as a die cast business in 1943 and Milwaukee has been around since 1924. Do you think they might make parts for each other or did Ryobi ( Japanese Co who has a manufacturing facility in China) make a cheaper part that uses the same number on purpose? I think you might be pretty safe with the cheaper part. Good Luck, this should Fixya!
Posted on Mar 19, 2009
  • 142 Answers
SOURCE: Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Posted on Dec 05, 2009
Testimonial: "Tks! Will try sandpaper inside collet. Not sure buffing bits will help, since likelihood of ALL of them having a surface problem is pretty low."
al_kupchella
  • 843 Answers
SOURCE: router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Posted on Apr 21, 2010
I have a B&D Router KW850E. It has collars and collet nut to take bits with 1/4 inch and 5/16th's shank. Can I get a collet nut and collar for 12mm or 1/2 inch?
probably not as the shanks of the router bits fit in the spindle shaft of the router which is around 1/2" dia
could always talk with manufacturer as to find an adaptor or like bit of equipment
Jan 19, 2017 | BITS Tools & Hardware - Others
How do I change bits on P/Cable 690LR?
If the collet was tightened without a bit in it, it may have been squeezed so it is too small for the bit shank. Completely unscrew the collet from the router and see if the bit will go into it. If not, you can try forcing an old bit in using your vice, and then using as hammer and punch to remove the bit, but most likely you will have to get a new collet. Just search "Porter Cable router parts to find a source.
Jul 19, 2014 | Porter Cable 690LR Router
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
Misshapen router collet
I don't recommend continuing to use a damaged collet. If the bit is not centered on the spindle or if the collet and bit are not balanced, the router is going to vibrate hard in your hands and cause chatter and a less-than-smooth cut on the wood.
Worst case scenario, the bit will vibrate out of the collet. You can imagine what is possible if that were to occur. I've had a bit come out of my router table...fortunately for me the bit nailed the table fence and bounced clear of me.
Hope this helps.
Apr 27, 2011 | Garden
Router bits
Apr 20, 2010 | Freud FT2000E 3 Router
How to connect 1/2 inch router bit into dewalt router
Are you asking how to put a router bit with a 1/2 inch shank into a router with a 1/4 inch collet? You need a 1/2 inch collet. Most routers with a 1/2 inch collet can also use a 1/4 inch collet. But smaller routers cannot use a 1/2 inch collet.
If this isn't clear, please ask again.
Al K
Mar 29, 2010 | Dewalt DW621 Routers
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
Ive got a kenzo router and the router bits do not fit . ive got quarter inche cutters and when the collet is done up tight the cuters are still not tight. its not a half inch router as ive measured it. any...
Your router bits must have a 6mm shaft, whereas your router with the collet closes down on a 1/4" or 6.4mm shaft. You will need to get a metric collet for your router spindle, or get a new set of 1/4" bits
Sep 28, 2009 | Freud FT2000E 3 Router
Bit slips out even with collett tight
That would be the only thing to cause this type of a problem. I had the same problem replaced the part and away I went like nothing ever happened
May 21, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
371 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
