Question about Hotpoint Microwave Ovens
Turntable not rotating - Hotpoint Microwave Ovens
  • 6,784 Answers
HI. The most common issue here will be a failed turn table motor. This motor is located beneath the actual table housing. replace this failed motor.
Note(The uncommon problem area will be a failed relay. although, highly uncommon, this may be the issue. i would advise to inspect the motor control relay located on the main control-board for visible burn marks)
Posted on Oct 03, 2009
Microwave turn table quit rotating
With the model number, we may have been able to give you a link to the actual service manual. Without it, we can only give you general answers.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes, then try it again.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
The turntable pad is used to turn it off for cooking without the turntable, then to turn it back on when you do want to use the turntable.You can find links to helpful exploded view diagrams and part ordering help here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
Aug 10, 2013 | Microwave Ovens
Turntable stopped rotating
Sure, if parts are available.
Apr 22, 2013 | Microwave Ovens
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Turntable
The turntable motor will need to be replaced, a common issue.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
Turntable does not rotate
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
I'd recommend that your bookmark this link to your favorites.
Dec 25, 2009 | Whirlpool Microwave Ovens
HI, the turntable motor is weak and failing at this point, simply replace this damaged motor. this will eliminate this distraction.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating on my microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes. You can download your owner's manual here: http://www.miele.co.uk/Resources/OperatingInstructions/M%20625%20EG.pdf On the last page it has the contact information for various countries. You can locate servicers or spare parts. The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58 If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Miele M625EG Convection Microwave Oven
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
