Question about Dymo LetraTAG Thermal Label Printer
Dymo Letratag prints as though ink is low
The summary says it all. Can I fix it or replace the ink cartridge?
whitesox
  • 64 Answers
SOURCE: Dymo LetraTag 2000 hand held printer
This Unit does NOT take ink. That is one of it's "benefits." Since it uses heat transfer, im thinking it either needs new batteries, or it's heat device has been expended. This is a cheap little maker, so it isnt made to handle the abuse of an office: it's meant for a label from week to week. If you went on a label spree all over the house, you killed it. Hope this helps!
Posted on Jul 26, 2007
loumsc
  • 114 Answers
SOURCE: Ink
You need to clean the printhead with q-tips dipped in alcohol.
Lou
Posted on Aug 25, 2008
bob_computer
  • 3153 Answers
SOURCE: ON my DYMO letratag Qx50 - the print is faint
Either the print head is failing or the batteries need replacing
Posted on Sep 18, 2009
  • 43 Answers
SOURCE: I have a Dymo Letratag XR and it is only printing
change the batteries! there is no ink, this problem is nearly always flat batteries...
Posted on Dec 17, 2009
SOURCE: Does a DYMO Letratag QX50 have a replaceable ink
It is a thermal printer and thus does not use ink.
The most likely cause of poor print quality is low batteries. Replace your batteries or plug in the power adapter.
If this does not help check that the label cassette is in place correctly and that the print head is clean. You could also try a new label cassette.
Posted on Jan 31, 2010
I have the Dymo LetraTag but not the thermal one. The ink seems to be running low. How do I refill it??
They're *all* thermal ones, none of the dymo printers use ink. When the print is fading it means the batteries are running out, so just replace them!
See the manual here on the Dymo Manuals and Drivers page.
Feb 03, 2011 | Dymo LetraTag LT100H Label Printer
I have a dymo letratag labeler and it doesnt print properly. its like the ink is running out
Dymo LetraTAGs are thermal printers, so they don't use ink - Change the batteries and it will fix the problem.
Jan 26, 2011 | Dymo LetraTag QX50 Thermal Label Printer
MY DYMO LETRATAG IS TYPING IN REVERSE WITH LOW INKING AS IF IT IS RUNNING OUT. I HAVE PUT A NEW CARTRIDGE IN. WHAT SET UP DO I NEED TO CHANGE PLEASE?
I FOUND THE MANUAL AND DOWNLOADED IT FROM A LINK FROM PREVIOUS QUERY. MIRROR PRINTING IS A STYLE AND THE POOR PRINT IS DUE TO OLD BATTERIES NEED REPLACING.
Jan 25, 2010 | Dymo LetraTAG Thermal Label Printer
The print on my dymo letra tag is very faint, how to fix?
The first thing you should do is check the batteries. Because the LetraTag requires heat to generate thermal printing, not ink, the batteries need to be well charged. Also, there is a small brush fitted to the inside of the lid of the cartridge cover, that is for cleaning the print head and roller. Remove it, dampen the felt tip with a little rubbing alcohol, and gently clean the print head and roller. You should find this will improve the print quality 100%
Oct 28, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Does a DYMO Letratag QX50 have a replaceable ink cartridge?
Yes, DYMO Letratag QX50 ink can be purchased on amazon, click here and take a look Amazon com DYMO Letratag QX50 refills. I hope this was helpful, cheers
Sep 18, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Ink ran out!? What to use?! or where to buy & how to use?!
Hi, the Dyno label uses no separate ink for printing. The labels are printed with thermal ink that's in the refillable label cartridge. Replace the cartridge and your back in business.
Apr 29, 2009 | Dymo LetraTAG Thermal Label Printer
How to fix a print cartridge issue? or is the Qx50 broken?
you have defective print cartridge.
get another print cartridge
Dec 17, 2007 | Dymo LetraTag QX50 Thermal Label Printer
Dymo LetraTAG Thermal Label Printer Logo
260 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
