Question about Canon PowerShot A410 Digital Camera
Camera gives E18 error!!!
My camera is Canon A410, 3 years old and in mint condition. There is not a single scratch on it. Recently when I tried turning on the camera after a gap of about 3 months.It does not turn on...Gives E18 error and there is a visible gap between the lens and the body. I tried every trick mentioned on this site but wont respond. Camera lens moves back and forth a number of times and simply switches off. Service in India is expensive for this old camera. What should I do???
    President:
  • 1,566 Answers
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Posted on Apr 06, 2010
What does E18 mean on the screen of my camera?
E18 is a lens error. You might try this repair technique:
Canon E18 Error
Jun 04, 2015 | Canon PowerShot A20 Digital Camera
Look at http://www.fixya.com/support/t7664765-cannot_turn_camera I cannot turn the camera on. I guess it was dameged during my holidaying. I recall that, the camera was excidently turned on inside its...
This should also work for your camera.
the E18 displayed on the LCD is an error code which means the zoom lens is stuck or obstructed when trying to extend. This is a common problem with many Canon compact digital camera models.
you can read more about this error code and a list of many of the cameras affected on this webpage: www.e18error.com
one possible cause for this error condition is something obstructing the tiny geartrain that operates the zoom lens (dirt, sand, etc). It may be possible for you to recover from this error by dismantling the camera and dislodging whatever is obstructing the lens or lens geartrain. Sending the camera in for professional repair will probably cost you more than buying a new camera, so it's worth your while attempting this repair yourself if you're up to it.
several of the Canon digital cameras I've seen are constructed in a similar manner and luckily use screws to hold the case together, allowing for disassembly.
over in the Teardown section here on ifixit.com, I've posted pictures of the stepsrequired to fully disassemble a Canon PowerShot S500 digital camera. Even if you have a different model Canon camera with an E18 error, you may find these photos give you an idea of what's involved in the repair.
Feb 24, 2011 | Panasonic KX-TG2740 Cordless Phone
E 18 problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 27, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
I have a Canon Powershot S2 IS which has worked great till recently it locks down for no apparent reason. I hear a series of beeps and see E18 in the bottom at left of screen. If the zoom is out, it...
Taken from a canon forum:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
-Basically what it came down to is if it's under warranty, get it replaced. If not, try using compressed air to blow out dirt and dust from the lens and all reachable components.
Or just gently push the lens back.
It is a Canon design malfunction and has happened on plenty of cameras.
My Canon 40D digital SLR loves to give me Error 5, and my flash wont pop up. It's just an unfortunate side affect of owning a Canon.
Apr 10, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
What is the E18 error and how do I fix it?
Lens errors (a.k.a. E18 errors on Canons) are fairly common in all digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 04, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
E 18 problem
Hello there,
Aug 09, 2008 | Canon PowerShot A40 Digital Camera
E18?
The following blog outlines some simple repair options for a E18 lens error:
Dec 23, 2007 | Canon PowerShot S100 Digital Camera
Canon PowerShot A410 Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
