Question about Sony KP-65WS500 65" Rear Projection Television
Kp-65w500 green flash... led blinks 8 times
Good picture for about 15-20 seconds.... green flash unit shuts off.
If I remove the connections from the green bulb.... set stays on.
Is there anything I can do to fix this thing?
  • brewyourown Oct 03, 2009
    Thanks for the help. I needed to make sure it was as bad as I thought. Now I have to get this beast to the dump.
    Top Expert:
  • Sony Master
  • 14,553 Answers
I am going to guess that model number is actually KP-65ws500
This is one of group of Sony sets that had bad picture tubes---red, green, blue----the tubes are no longer available and can only be obtained by removing the bad one and sending it out for rebuild (very expensive)
There is one easy thing you may be able to do to correct this problem---It involves no replacement of parts and is just adjusting the Green screen control---usually if this is the case when set comes on background will be somewhat (in your case) green---best way to see this is turn set on and have it on a unused video input---if screen appears somewhat green and has curved retrace lines--you may be able to turn the Green screen control down and continue to use the set---set will shut down if any of the 3 picture tubes pulls too much current--ie--goes to bright green, red or blue.
Let me know if you want to know how to attempt this
SD TECH
Posted on Oct 03, 2009
Testimonial: " Turned the green control all the way down.picture.. flash..picture.pop..pop.dielectric..small . smoke from green assembly.removed power. Its toast."
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen goes green then black
That model is famous for bad picture tubes, and thats the classic symptom of a bad tube shutting the set down
Jun 25, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony 57 projection flashing blue green and shuts off blinks 8
if its hot cool it if that isnt it reset it by unpluging it and holding the power button while unpluged
Mar 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Sony tv red flashes
I hate to be the bearer of bad news, but you have a shorted red picture tube.It is not at all uncommon on sony rear projection. The gun shorts and the set identifies the problem and goes into shutdown. Usually there are diagonal lines in the picture before it shuts down. this is an unfortunate problem because this set delivers a great picture. The dealer cost of the tube is around $200. When the repair is complete your're probably looking at $400-$600. The only problem is that the green tube and the blue tube also have chance of having the same problem. It'a tough call . But from my experience , I have replaced the green tube and had the blue tube goe within a year. Scrivitron
Jun 21, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-65WS500 65" Rear Projection Television Logo
344 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
