Question about Minolta EP1083 CS/PRO Copier
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
  • Minolta Master
  • 1,297 Answers
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Posted on Oct 03, 2009
How can i fix Cof30 in my copier minolta ep1085
replace the developer first, if not then get a new ATDC sensor located under the developer unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 09, 2015 | Minolta Office Equipment & Supplies
I have a KONICA MINOLTA bizhub 7115, but I do not know the code developer (ATDC - auto adjust), please let me know. thank you
Has the developer been replaced? do not run this auto adjust unless that has been done. 36 mode will get to auto adjust.
Mar 03, 2015 | Konica Minolta Office Equipment & Supplies
Copier is printing dark lines throughout the pages
Mite need to have the drum replace and check the charge corona housing above the drum when you pull the drum unit out.. Also check the fuser unit the hot part.
Jan 17, 2014 | Minolta EP1083 CS/PRO Copier
How to rest toner from black background
If the copy is dirty background first clean the optical parts component,mirror,lamp,charge corona,transfer unit.If it is OK verify the imaging unit developer and drum,if necessary change it.
Nov 30, 2013 | Konica Minolta Genuine Di181 Di-181 Ep1085...
Wrench symbol on Konica 7115 means what?
PREVENTIVE MAINT. Replace drum, cleaning blade,developer etc. comes as a kit for the technicians to replace, clearing counter without doing things not good machine uses the counters to adjust voltage on certain parts and is the only way it knows new parts installed clear counter and not replace parts causes codes and image problems
Jun 25, 2012 | Minolta Office Equipment & Supplies
Minolta cspro ep1085 need to know if there is a hard drive in this copier
No there is no hard disk drive in the EP1085. This was an analog machine and as such had to provision for PC connectability, printing or scanning. Therefor no hard drive needed or offered.
Thank You for using Fixya!
WheatlandServices
Sep 30, 2010 | Minolta EP4000/5000 CS/PRO Copier
Hi everyne PLEASE HELP ME i have a problem with
SORRY. YOUR MACHINES FUSER OVERHEATED CAUSING THE 502 CODE. YOU CAN NOT RESET THIS CODE IT IS A SAFETY
LOCKOUT. A SERVICETECH CAN RESET IT CHECK THE FUSER
AND GIVE IT A CLEANUP FOR ABOUT 200.00 IF FUSER PARTS ARE NEEDED IT MAY TOTAL 400.00
May 11, 2010 | Office Equipment & Supplies
Problem: Minolta EP2080 copier prints all dark
The base exposure adjustment is out on adjustment, there is an small access cover inside the front door. remove the phillips head screw, and the cover should expose the tech adjust area, in there you should find a trim pot marked EXP. set the exposure to manual center, then adjust the pot until the copies look good.
Hope this is of some help.
Ed
May 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta 2050 with ATDC set as 140 and current as 0%
Hello sir; replace auto toner sensor will be ok, that sensor is located on developer unit.
Dec 24, 2008 | Minolta EP4000/5000 CS/PRO Copier
Copier only copies 90% of sheet in 100% mode
you have to go to service mode to adjust it that's ,technician's job,better looking for a local service provider
Dec 09, 2008 | Minolta EP1083 CS/PRO Copier
492 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
