Question about Desa International Hot Surface Ignitor Heater
How do I install a furnes ignition? - Desa International Hot Surface Ignitor Heater
  • 80 Answers
For safety reasons, this is best left to a professional. Most times, these are not direct replacements. Manufacturers can change parts or original manufacturer of the part. More often than not, the replacement is an upgrade retrofit.
Posted on Oct 03, 2009
My 1996 E350 camper does nothing at all when I furn the key .batteriy is charged .Nothing at all happens,not even a click.no lights at all
If you have no dash lights or anything, check fuses first. Then replace the ignition switch. It is a 96. You could have problems with the plugs threw the firewall also.
Oct 17, 2016 | Cars & Trucks
When i furn hot water on in kitchen it takes 5 leter water to get hot
quite possible that there is 5 liters of water in the pipes between your water heater and the faucet. if this is unacceptible, install an on demand water heater under the kitchen sink
Aug 18, 2014 | Plumbing
My toyota ipsum .1997 model is overheating.The furns do not turn automatically as it it suppose to be when the temperature rises.a furn switch was changed but this did not solve the problem.The furn is...
i had a similar problem till my mechanic advised me not to exceed the full mark on the radiatior overflow bottle. so simple a solution, but it worked.
Feb 05, 2011 | Heating & Cooling
Looking for manual for old Sunbeam CoffeeMaster model C30C. Failing that, it looks like a percolator on top of a carafe. How do I get the carafe off to pour the coffee?
Grasp the lower handle with your right (or left) hand, use your thumb to push up on the upper handle. This will push the top up at an angle and allow the seal to break gradually.
Mar 08, 2010 | Coffee Makers & Espresso Machines
Turn signals are not working
Turn signals are powered by a relay plug in the fuse box. Replace the relay and the furn signals should operate.
Feb 15, 2010 | 1999 Volkswagen Passat
The pressure switch stays closed and it won't ignite the furn
Hi in most cases they cannot be repaired a new pressure switch is required
Feb 06, 2010 | Goodman GMS90703BXA Heater
Well my car overheats and the fan dose not furn on
test fan opperation, if good try changing the thermo switch, check fan relay and fuse
Jul 01, 2009 | 1994 Honda Civic
Unplugged phone to put in new furn. plugged phone in and handset does not answer. It does respond to base.
Make sure the phone line at the base unit is plugged into the LINE position, otherwise you probably have a wiring issue.
Jul 27, 2008 | Vtech Lands Phones
Heating & Cooling Logo
32 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
