Question about Polaroid FLM-2601 Television
TV won't come on. Blue light blinks, but TV does not come on?
Same exact problem, same exact model the FLM-2601. I followed the steps from a you tube video at http://www.youtube.com/watch?v=OqZG1F_h1CA and had no difficulties removing & replacing the 25 watt capacitors with new 35 watt capacitors, after a quick $10 radio shack shopping spree. The most difficult & time consuming part of the task was removing the housing & its numerous screws, of various thread type, length & diameter...needless to say it is possible. Only 3 extra screws remained after the set was working again. The television is working great again & was well worth taking the time to research the problem and find a solution that I was comfortable in performing myself. I didn’t think my soldering was that great of a job, but the television works great.
Posted on Dec 10, 2009
  • 11,361 Answers
You can download the service manual here: http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
  • Polaroid Master
  • 5,568 Answers
Probable power supply failure; I'll paste my usual suggestions below-
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload and the power supply for the backlight may be at fault.
Posted on Oct 03, 2009
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
My onn tv won't turn on the stand by blue light just keeps flashing !!! Does this mean it has gone to tv heaven ???
Often it can be as simple as bad capacitors on the power supply board, or if you cant desolder and solder replaceing the power board will usually solve a blinking power light for certain LCD tvs depending on model number but I would need your model number to further assist for your paticular situation
Dec 16, 2012 | Televison & Video
My sharp aquos 52" power button is blinking blue and won't come on.
power supply which can be ruled out or confirmed with voltage checks on that board.
Aug 31, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My 42' hisense tv turns on then blinks. blue then
Take it to a servicer with proof of purchase or back to the store. You will get it repaired for free or get a new TV.
Apr 19, 2012 | Televison & Video
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
When I turn the tv on it show a blue light but now the tv won't turn on and a red light keeps blinking. What should I do?
Replace the defective electrolytic caps on the power supply and/or replace power supply, check at www.partstore.com That should fix your problem.
May 31, 2011 | Proscan 32LA30Q Television
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
I need the USB firmware update utility for a JVC LT-32P679 TV.
my tv won't show a picture the blue light on the bottom left hand corner just keeps blinking
Apr 05, 2011 | JVC Televison & Video
Tv won,t come on now
i have a kp51ws520 that i just fixed. it blinked 9 times. found out it was the g board. got it done pretty cheap . let me know if you need more info.
Feb 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
Polaroid FLM-2601 Television Logo
997 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
