Model # FAM 18752A item # 205400 I mistakely punched the timer button and now it goes on and off every 5 mintues. I have tried turning if off and then back on, unplugged and tired it again. I have also pressed the reset button on it after I turned it back on each time. Also I have lost my manuel and need to know how to get a replacement
  • Josh White May 11, 2010
    What is the brand and what type of equipment is this.
One if your assistance help me with the problem.
Posted on Oct 05, 2009
SONY LED MODEL:40r452a MADE IN MALICIYA
The power supply could be failing
Dec 22, 2017 | Sony Televison & Video
I recently replaced the TY-LA1000 lamp but I'm getting a yellow flashing light that goes on every 5 secs.I made sure that it was installed correctly and tried resetting the timer by pressing + and - o
Yellow flashing light? Did you get any picture? Bet, not!
It means: your lamp door interlock is not engaged: did you forget to turn the locking knob? Did you install lamp compartment door? That might be the only issue. Lamp timer blinks 'red", while TV works normally. Reset the timer, it's gone, along with annoying message. Yellow means: interlock or thermal protection is off. Try to repeat lamp installation procedure. then, you'll find out your mistake. don't need to remove the lamp. It would be "red", if lamp won't fire up.
good luck,
Alex.
Dec 06, 2011 | Panasonic Televison & Video
Just installed a in-wall digital timer model 59018 and when we try to program it when we hit the clock button the unit shuts off so we are unable to set the time (or anything)
Woods 59018 single-pole 7-day 7-program timer, color white:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Jul 04, 2011 | Woods InWall 7 Day Digital Programmable...
The only thing working is the digital display and the input keys -- motor and heating element do not work. model 1196 toastmaster
Reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 16, 2011 | Toastmaster Kitchen Appliances - Others
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
I have a Sony WEGA KDF-E60A20 for 4-5 years. A few mintues after i turned it on, the screen goes blank with no sound. It comes back after 1-2 minutes. It goes blank again after 2-3 mintues. It just keeps...
It's the lamp. I do have an article on this in my Tips & Tricks regarding lamps, but replacing the lamp is a sure fix. I hope this was helpful, best wishes.
Apr 29, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sharp model 1874 when you punch in the mintues it will only go to 59 seconds and shuts off. if i hit 10 mintues it will stop at 9:01
change damper motor and switch. cost is approx $30.00. unit must have cover removed to gain access to motor & switch
Bob
Dec 15, 2009 | Sharp R-1874 Convection/Microwave Oven
I have a holiday living power stake timer, how do i program it?
I have the directions for this item and tried to paste them here, but exceeded the amount of space allowed. Will send in several replies. FIRST:
HOLIDAY LIVING HEAVY DUTY OUTDOOR DIGITAL POWER CENTER
MODEL #LW28080 ITEM #0050024
INSTRUCTIONS:
NOTE: To set up Timer for the first time, plug in the timer for 10 minutes, then insert a sharp pointed object or opened paper clip into the pin hole marked "RESET" to clear all settings.
SET THE CURRENT TIME
1. Press the CLOCK button.
2. Press the DAY button to set the current day of the week.
3. Press the HOUR button to set the current hour. Be sure to take note of AM / PM.
4. Press the MIN button to set the current minute.
5. Press the ENTER button to finish setting the time.
Note: If you do not touch any buttons for 10 seconds, it will automatically save the time.
Continue to Digital Timer Mode or Photocell Timer mode below.
To have your lights turn on and off at specific times throughout the week, choose Digital Timer Mode.
To have your lights turn on every day at dusk and off at dawn or after 1 - 12 hours, choose Photocell Timer Mode.
Nov 21, 2009 | House Brand Hardware & Accessories
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
HD TV flat screen
there is a timer that you can set to turn the tv off automatically. The timer settings is between 30 min. and 3 hours, maybe she has hit the timer button by mistake.
May 31, 2008 | Televison & Video
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
