Question about Belkin (F5D7230-4) Router (587009)
The easyinstall gives me an error dll not found
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
May 12, 2010 | EA - Electronic Arts Command & Conquer 3:...
I can't change my background
Hi
Download shell32.dll from the following link, and then type "regsvr32 shell32.dll and press Enter" at Run Command in Windows 7.
When you click the following link a page will open, Click Download shell32.dll to download the file.
http://www.dll-download-system.com/dlls-s-/shell32.dll.html
If you face any issue, please let me know.
This solution is absolutely FREE, please rate and give your feedback.
May 10, 2010 | ASUS P5PE-VM Motherboard
I have the same regsvr32 wintrust.dll error code 0x80070005 i cant log into my hotmail. i found in another forum that i should try running the following: regsvr32 softpub.dll regsvr32 wintrust.dll...
- Double click on the clock in the taskbar and make sure the system clock is set correctly.
- Disable Zone Alarm
- Register softpub.dll using the regsvr32.exe tool.Click Start, and then click Run.
- In the Open box, type regsvr32 softpub.dll and then click OK.
- Do the same for the following regsvr32 wintrust.dll, regsvr32 initpki.dll, regsvr32 MSXML3.dll.
- Restart Windows Live Messenger.
If you are still unable to fix Windows Live Messenger your computer might be infected, I recommend you Download registry cleaner to fix your errors and speed up your computer.
Aug 21, 2009 | Microsoft Windows Xp Home Edition English...
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Jun 07, 2009 | Office Equipment & Supplies
PowerCinema for Toshiba error message
Here we go, just paste this site in your browser and download the dll. This should correct your problem:
http://www.dll-files.com/dllindex/dll-files.shtml?msvcr71
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
http://www.driverskit.com/dll/msvcr71.dll/2373.html
Mar 07, 2009 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
