Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore top-loading washer won't spin
I have a Kenmore washing machine (Model number 110.92281800) that has stopped spinning. I had a load of laundry washing in the machine, and it came to a sudden stop with a load bang and jumped forward about one-half foot. Now it won't spin.
I checked underneath the washer and found that a gasket (I'm guessing that's what it is) isn't properly seated. At first I thought it was some kind of belt, but I later found out that this model is not belt-driven. I'm wondering if the gasket issue is a source of the problem or a result instead. The gasket seemed loose and had a few gashes in it. I placed a coupling on order through Sears, but I'm not sure if it will help or not since I have no idea where the coupling is located.
I'd appreciate any help I can get with this issue.
Take cabinet off, from the front, control panel first, then lay on back and take water pump off then motor off and you will see where the couple goes on. Pretty simple job how ever you may be missing some transmission clutch plates that will make it grab and stop with a bang like that.
Posted on Jul 06, 2010
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Washer will wash but won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | Kenmore 22422 Top Load Washer
Model no. 23832, won't spin, lid switch is good and so is motor coupler. HELP
heatman101
Aug 09, 2011 | Kenmore 2383x
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
188 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
