Question about Husqvarna Chain Saw 20" Bar
I have a mdl# 55 chain saw it was running fine and than just stops,it will restart but after a small run it stops again and it will keep starting and stoping.
  • 360 Answers
SOURCE: saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Posted on Feb 16, 2009
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
steve_lima
  • 181 Answers
SOURCE: weak spark on 55 rancher chain saw/ airgap on magneto
the air gap is .010 to .012 inches,hope this helps, if not contact me and i'll help you with anything i can
Posted on Mar 12, 2009
  • 334 Answers
SOURCE: husqvarna small chain saw won't stay on and now won't start
check your pick up coil . i had one it done the same thing to and that what it was
Posted on Apr 02, 2009
  • 26 Answers
SOURCE: 55cc air induction chain saw wont start,keeps flooding
what do you mean by flooding?
if it is overflowing?
try to remove the 4 screw underneath the carb,
take out the diaphragm,and then followed by float valve..
there is a tiny spring,be very careful...
stretch the spring a lil bit more at about 2mm...
as time passes,the diaphragm deteriorate and one way to correct them is by stretching the tiny spring to give more strain on the diaphragm...
this is what i did if i am too lazy to go out and buy the diaphragm kit..
only 10 bucks...hehe
Posted on Aug 06, 2009
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 55 chainsaw has a problem running on idle
start by checking all ur fuel lines for holes then proceed to clean or rebuild ur carb the ethonal in fuel is cloging small engine carb jets and making needles stick so then adjust ur carb back to factory settings try with new air filter as well and run 89octane or higher in your two stroke motors u will c a great differance in performance
Dec 13, 2012 | Husqvarna Chain Saw Models 51, 55
I am using a borrowed Husqvarna model 51 chainsaw (aprrox 18") and having a problem with the chain seizing up. It worked fine for 30 minutes or more, and then the chain suddenly had much more...
Sounds like the bar is to tight.There should be a cover and 2 studs,loosen the nuts and then look for an adjusting screw at the back of the bar and back it off.The chain should have about 1/8 slack when pulled from the bottom of the bar.A tight chain will heat the bar and turn it blue close to the chain guide.A new bar will be required. Thank you for using FixYa .
May 11, 2011 | Husqvarna Chain Saw Models 51, 55
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Chain keeps losening up
Is the chain being properly oiled as it runs? Check by running the tip of the bar at speed near a piece of cardboard for several moments--it should throw off a thin line of oil onto the cardboard. If nothing, remove the bar and chain, start the engine and observe the oil port in the side of the engine case. At speed, it should ooze out oil. If so, clean the bar drive-end holes that feed oil to the chain. Pay particular attention to the two small holes that run from the large holes out to the chain groove. If nothing comes out of the engine port, then an inspection of the pump, lines, and tank filter are in order. Make sure the chain is properly sharpened as a dull chain makes a lot of heat which allows the chain to stretch. You should not have to apply high force to the saw to get it to cut. Set chain tension so that the chain does not droop from the bar bottom, but turns easily by hand. Hope this helps!
Apr 09, 2010 | Poulan ES350 16" Chain Saw
Husqvarna 55 chain saw has no power. Runs and idles OK but when I put the blade to wood the chain quits turning. It doesn't sound like it rev's as high as it should. I took off the air filter and ran it....
WITH A SMALL SCREWDRIVER ,SCREW BOTH HIGH AND LOW ( H&L)SCREW IN TILL THEY BOTTOM OUT ,NOT HARD, BACK THE H SCREW OUT 1 1/4 TURNS AND THE L 1 1/8 OF A TURN START IT UP ,TAKE TO MAX REVS,PROBABLY BEST TO HOLD CHAIN BAR IN VICE SOTHE CHAIN RUNS FREE,THEN TURN THE H SCEW IN AND OUT UNTILL IT RUNS THE FASEST AND SWEETEST THEN BACK IT OFF 1/8 TH OF ATURN LET IT IDLE AND DO THE SAME WITH THE L SCREW,YOU MAY HAVE TO ADJUST YOUR IDLE SPEED NOW, BUT THEN YOU SHOULD BE RIGHT
Sep 25, 2009 | Garden
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 | Garden
Weak spark on 55 rancher chain saw/ airgap on magneto
Mar 12, 2009 | Husqvarna Chain Saw 20" Bar
Feb 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
83 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
