Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
25cc craftsman won't start
Took it apart and can start it if you push some black lever in that pops back out when you press to engage the string. It only runs for a short time and shuts off.
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
How do I take apart craftman 25cc gas weedeater to replace the string?
Same problem here......need to replace the trimmer string......some of you guys and probably some ladies know this...Ple Don't know which way to turn the head to get it off, or if I also need a tool to remove it. Please help!
Aug 21, 2011 | Craftsman 25cc Gas Line Trimmer
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 25 cc string trimmer with fuel problems. After winter, ran tank of good fuel through it and it worked fine. Added fuel (unknowingly with water in it) and it ran on a slow idle and...
You shouldn't notice a difference if you remove the air filter. So I would replace it. Also if you are using compressed air to clean or blow-out the carb. Be careful, its not recommended and could make it worse.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
